-   Porsche Autocross and Track Racing (http://forums.pelicanparts.com/porsche-autocross-track-racing/)
-   -   New- Open Source Race Data Logger (http://forums.pelicanparts.com/porsche-autocross-track-racing/725342-new-open-source-race-data-logger.html)
Plavan 12-24-2012 11:28 AM
This Data Logger looks very promising. It is open source and the price is really, really right. Much less than my Traqmate.
No affiliation, but I did order the $299 package for the new race car incoming in 2013.
A lot of options (Real Time Cellular streaming data, Gopro, etc)
Check it out.
Race Capture Pro - Data That Drives You | Indiegogo
phigreg 12-24-2012 12:34 PM
Data logger
OK, I tried it also
Greg
flat6pilot 12-26-2012 12:56 AM
Looks great. My girlfriend and I each bought one of the 299 packages plus the 55 Bluetooth addon. They've reached their 30k goal now.
Plavan 12-26-2012 10:15 AM
Very cool. Now we get the free shift light too. I'm looking forward to checking this thing out on my new race car. However, it comes late 2013 :( so there will be a lot of waiting.
ErVikingo 12-27-2012 07:41 AM
Forget about the data logger, do tell about the new race car. You are not allowed to tease like that.... SmileWavy
Plavan 12-27-2012 08:05 AM
This is what I am waiting for. I preordered it. A 818R from Factory Five. Not a Porsche, but for the cost of Cup Car maintenance you can have one of these. The Race version 818 is around 1500 pounds, then add a turbo charged WRX STI turbo motor and trans (Mid Engine). Then you use some stock suspension components off of the regular WRX.
Best of all, you build it yourself. That's what I love. Just imagine 1700 pounds with me in it and 350HP...... I think anyone would love that for a race car.
http://forums.pelicanparts.com/uploa...1356624149.jpg
ErVikingo 12-27-2012 01:34 PM
Spectacular Chad!!!!
I'm not a fan of open top cars but, wow. Spectacular! congrats and Happy Holidays.
Plavan 12-27-2012 02:05 PM
Thanks- I feel the same way with open top cars. However, it looked too fun to pass up.
Walt Fricke 12-27-2012 02:20 PM
Open cars are a blast if you can supress your imagination.
The tops of my helmets have born witness to where sand and rubber chunks go. A bird shat on my visor (tearoffs useful). When I split a rabbit in half, part of the upper half hit me, making this a blood sport I suppose.
Sitting on the grid in the hot sun less fun, driving in the heat less painful.
But I'd not build a low front hoop car. They must be safer than they look, or there would not be so many variations of them racing in pro and amateur series. But that front bar is comforting even if it negates some of the aero advantage the smaller frontal area provides.
But I am sure you will quickly get used to it, and stop worrying about someone's wheel coming off and sliding up your hood parallel to it. (If ever I redo the roll cage, there will be some flat steel slats in front of me - edge on your eyes see right around them).
We racers are not given to worrying overly much, or we wouldn't race.
Plavan 12-27-2012 04:02 PM
Here are the Prototype pictures. I hear you on the roll cage. I have worried about that and may add some bars forward.
http://forums.pelicanparts.com/uploa...1356652900.jpg
http://forums.pelicanparts.com/uploa...1356652918.jpg
Walt Fricke 12-27-2012 06:33 PM
Different bar setup in the 2d set of pictures. Looks a bit sturdier, or at least more likely to be accepted instead of the two hoops in the 1st picture.
I suppose the height of attachment of the several braces to the main hoop meets standards for that? I guess they are "as high as possible" without being on a curve.
How does one get in/out? For my car with full roll cage I put a foot on top of the door (which is non-functional, and has a small tube right under the top for this very purpose) and step over the top bar and drop down in. Exiting is reverse. So the side diagonal isn't in the way of my usual scheme. This is a common enough scheme, so there must be a simple enough way.
Awsome performance potential.
Jeff Alton 12-29-2012 09:51 PM
Been following these, but had not seen these pictures..... looks good. Will wait to see actual weights from completed customer cars and some inititial impressions though.
Keep us posted Chad!
MotoSook 12-31-2012 08:04 AM
Looks like a very cool car, Chad!
As for the data logger, I've been looking for this exact thing for years! User configurable inputs and outputs.
So help me with this format...I'm slow..I know.
They are taking pre-orders to fund the production, which may be ready for delivery in March 2013. Since they hit the $30,000 mark, there is a good likelihood that they will go into production and delivery in March? Correct?
What aboutthe sensors? Is there a source for all the sensors? Or will we have to searchsource for the sensors ourselves? Not too worried about this, but it sure would same me a lot of time to be able to click and buy this stuff.
cstreit 12-31-2012 10:44 AM
I'm betting it's just an A/D converter to tapping into existing sensors.
flat6pilot 12-31-2012 09:26 PM
The sensor input is 0-5v which is what most automotive sensors use. Generally speaking most aftermarket sensors should work. If they don't, you would be able to configure them through the open source nature of this unit.
The units should start shipping in march. Brent Picasso can be found on Facebook and can be easily reached for questions.
9dreizig 01-01-2013 04:44 PM
any chance they will have an ability to link with video ? Say a Go Pro ?
flat6pilot 01-01-2013 10:50 PM
Yes. Brent has made a harness to allow the GoPro to start/stop. Since you can program the CPU, you can even program the camera to auto start/stop at a certain GPS speed for example. Your whatever you want.
It will allow multiple cameras also (only limited by digital inputs to the ECU)
This is the GoPro hd. I'm sure they're working on a GoPro 2 harness.
9dreizig 01-04-2013 09:09 AM
So I"m assuming you could use a windows tablet or other as a dashboard ?
flat6pilot 01-04-2013 03:13 PM
Yes, it has software written for the Android phone and tablet.
You should be able to access and configure the unit from the tablet. It's via a Bluetooth connection only as far as I know. I'm not sure if there was a hardwire connection. Didn't ask.
iOS for iPad is also in the works but no ETA.
Plavan 01-04-2013 03:24 PM
The only thing I'm worried about is the tablet display use in sunlight. Usually not that good.
9dreizig 01-04-2013 08:17 PM
Chad, don't forget it would be mounted under a shroud where your speedo, etc normally would be.. so hopefully will be shaded..
9dreizig 12-02-2013 11:10 AM
Any update on this from someone who bought it ?
Plavan 12-04-2013 07:52 AM
I have it- But have not installed yet. I bought it for the Racer I'm building in the garage now. They have all sorts of stuff for it now. I cant wait to use the Bluetooth module for the Nexus 7 tablet dash.
818R as it currently sits
http://i.imgur.com/IlZuEcEl.jpg
cstreit 12-04-2013 07:56 AM
Looking forward to seeing it. Now that some details have come out, looks like a pretty neat setup if you have the time to set it all up!
9dreizig 12-04-2013 08:26 AM
how's the software ? I heard it was pretty rough ?
Plavan 12-04-2013 10:45 AM
I have not messed with it at all yet.
KTL 12-05-2013 08:42 AM
Good choice going with the red calipers. Years of rigorous MotoDelta testing has proven w/out a doubt that red calipers are the fastest. :D
Congrats on the new car build. Looks like a fantastic platform. SmileWavy
kdjones2000 01-28-2014 11:18 PM
The software for Race Capture Pro is still being developed, from what I have heard from people who have it and have used it.
We use Wifilapper, a free, open source application for Android phones/tablets which can be connected to OBDII interfaces via Bluetooth, and if you want to build your own analog data acquisition system you can get up to 9 input channels from an IOIO board.
The software for WFL is (IMO) more mature than for Race Capture Pro, at least with the Windows version. There is a cellular data option for it, but that portion is still not ready for prime time.
Here is an example of data collected, in real time, from a trackday. We have used this system for several endurance races as well:
http://imagizer.imageshack.us/v2/102...0/515/hapf.jpg
https://sites.google.com/site/wifilapper/
Cheers, Keith
Note: I helped with the coding on the PC version of the software for WFL, so I may be a bit biased :)
Kyle at Pelican Parts 02-10-2014 03:45 PM
Pelican has been offering the Race Capture Pro, Telemetry Unit, and Bluetooth Dongle for a few months now. We have one in the office that we've taken to a few track days and even with a basic, barebones, temporary install we have found it to be a really useful tool for improving lap times. I can't wait to do a full install in a car with sensor integration, etc. I think it will be absolutely fantastic. Feel free to shoot me a PM or an email (kyle@pelicanparts) if you have any Racecapture questions and I'll do my best to answer.
Race Capture PRO at Pelican Parts
