Wave Trac Diffs. Any Issues
I put a new Wave-Trac in our 915 gearbox and ran it for a few laps on the track. The symptom was a feeling of drag after shifting it into 5th after a few laps. Before the gear box heated up, it seemed to be ok and the 3rd and 4th gears seemed ok until it was shifted to 5th.
Disassembly of the gearbox found some greyish colour in the oil( was new Swepco201) and what appeared to be friction material. I can only think it is coming from the Wave-Trac. I am hoping others may have a view on this. I am planning to call Wave-Trac on Monday morning The car is a full race spec 914 Thanks Geoff |
I am FAR from an expert, but if I understand the Wavetrac it is essentially a Torsen-type diff with a clutch-type device that activates under very low load / no load.
Therefore you have friction materials sliding against each other like a more traditional clutch diff. While the plates seat / break in with each other, they're going to grind down a bit. Pretty sure that's why oil looked dirty. Most aftermarket clutch diff manufacturers recommend a diff (or in the case of a transaxle, gearbox) oil swap after break-in. Perhaps the debris from the break-in affected your synchro action?
Matt - 84 Carrera |
gearhead
To my understanding of it, there aren't any clutches in a Wave-Trac. The part that mimics an LSD is the pressence of pressure rings that push on the gears to lock them together. See video:
Wavetrac® Differential - A torque biasing differential with a difference
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Thanks Matt. No matter how many videos I watch, helical diffs are witchcraft to me. Throw in an extra complication and I'm totally lost.
Matt - 84 Carrera |
No expert here, but I do have a Wave-trac in a 915 box with 4 track days so far with no issues. Lot of variables in the transmission including assembly that could be causing your issues. Friction material in a fresh 915 could just be the synchros wearing in.
Rick 1978 911SC |
How do you guys like the wavetrac? Is it a noticeable improvement over an open diff?
BMW 128i 73 rsr clone - sold 68 912 project to become 911r (almost done!) |
Rick 1978 911SC |
Wavetrac
Hey Geoff, I too have a wavetrac in a 915 behind a 3.6 varioram in a 2000lb 914. It is a full time track car that i have been building for 2 years and will be on the track in August. Anyway I was wondering if you heard anything from wavetrac about the grey mucus? Thanks!
Wave Trac Follow-up
Thanks to all who provided comments to my original post concerning Wave-Tracs. We did call Wave-Trac and they were very helpful. My race mechanic spoke to them at length covering the principals of how the Wave-Trac works, why the oil turned a greyish colour, how to test the diff unit etc. Based on the discussions and testing of the unit we are satisfied that it is operating as its supposed to. The real test , of course, will come in the next on-track test after we re-assemble the gearbox.
As for the source of the problem we went looking to solve, noise and a drag in 5th, I have to say we haven't found anything that was not the way it should be in the trans or clutch assembly. So then, only thing to do is try it. I will try to circle back and close this thread after we have tested it with some further comments. Thanks again for your responses. Geoff |
I have not heard of any recommendations to change oil...what does Wave-Trac say?
