Go Back   Pelican Parts Forums > Porsche Forums > Porsche Cayenne & Macan Forum
A/C--heater
hey guys I've been working on my 2008 cayenne 3.6 that I haven't driven for two years, and one problem I'm having is I have hot air coming out the drivers side vents and air conditioning coming out of the passenger side I have changed the blower motor actuator and checked the freon in the A/C and the problem still persists.
Any suggestions???
Old 02-03-2021, 05:37 AM
My other ride is a C-130J
RNajarian's Avatar
Are you able to pull any codes from the ODB2 port. My Durametric scanning tool is pretty good at identifying problem components.
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic
2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer
Previously Owned Art from Stuttgart
2000 Boxster -1983 911 SC Cab -1984 944 N/A
Old 02-09-2021, 01:59 PM
I do not have a Durametric scanner and this problem isn't showing up on a regular scanner
Old 02-11-2021, 04:44 AM
RNajarian's Avatar
I cannot speak for your situation. . . but when my A/C was acting up my Durametric identified the exact part. You should check and see if your ODB2 can identify individual parts.
I believe the good professional grade scanners can as well. If you are friends with someone in a shop it would behoof you to ask him to run the codes.
Old 02-11-2021, 08:02 AM
