2006 Cayenne Turbo S
I am looking at a 2006 Cayenne Turbo S for purchase...The current owner says it drives but hesitates it will drive but not drive far before shutting off???
I guess my main question is how much of a headache is it to bring it back or is this something I should forget about it and run the opposite direction??? It's less than 5K for local pickup...Is this something worth grabbing up? |
Those are great cars, but whether or not it is fixable is hard to say form what little we know. Might need an engine or just a coil pack. If an engine, that is more than the car is worth and you will probably sell for parts.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
Information Junky
Sounds like a fuel pump dying.
See: https://forums.pelicanparts.com/porsche-cayenne-macan-forum/862745-955-turbo-starts-fine-stalls-dies-after-2-3-secs.html
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
Thanks for the input...I am going to see the car in person tomorrow so I will let you guys know what I think...
So! I ended up not buying the Turbo version...It had too many problems for my baby budget to start with...I found a nice 06 "S" model that just needs some TLC for now. Thanks all for helping me make an educated purchase on this thing.
NOW! What are some of the things I should be doing first off...I am going to do a oil change real soon maybe this weekend coming...
Thanks all |
Great looking vehicle.
I don't fix anything on mine that isn't broken. It is smart and will generally tell you (with codes/check engine) when it is. Typical issues are fuel pumps, coolant leaks, coil packs and the driveshaft bearing carrier. It is heavy and will need tires fairly often and brakes if you are not gentle on them (but a sensor will tell you when the brakes are worn). Change the oil.
So...Just yesterday after work...the check engine light came on??? Uh Oh? Right! I've had the car for two days! Boy my luck...Lol! So, I went into Advance used their checker to see the codes and P2189 came up...According to the reader it is running too lean??? and it said if I had drivability issues to stop driving it??? The problem is the car drives fine??? I actually drove it from New Port Richey FL to Lakeland FL about 70 miles on Sunday then back and forth to work these last two days...The car drives fine but the light is on??? So far I filled the tank and added two 16oz bottles of seafoam in it since the light came on...I have not done anything else but that...I think I should drop it off at my local mechanic who works on my 944 to see what he thinks of it and if I should keep it or just give it back to the place where I brought it from??? Ugh!!!
It does not sound horrible...but nothing is cheap to fix on these. Sometimes it takes a while to find a leak/problem...so troubleshooting time adds up. It sound like you have a leak (air) somewhere and are running lean because of it. Seafoam will not help. You need to find the leak. Check intakes/hoses/MAF to see if they are light/in good repair.
If you just googled up the fault, you need to be more specific and add "cayenne" to your search...as these cars are often a bit unique. You may be able to get the seller to fix, but they probably just cleared the fault to sell it to you (and knew about it)...so, I doubt it. A decent P-car wrench should be able to fix and reset the fault.
I would guess that they did not seal a hose correctly when they put it back together. It doesn't take much of a leak.
I had a leak a few years back before I started working on mine much. It took my independent wrench several hours of labor to find it. Sometimes air leaks are tricky.
The mechanic was not in today so tomorrow?
Is there a PET for our cars like they have for the 944??? |
Yes. I downloaded one from this link:
https://www.porsche.com/all/media/pdf/originalparts/en/E_9PA_KATALOG.pdf
Cool I am starting to sense this thing doesn’t have blue tooth??? It has phone features I think but there’s doesn’t seem to be a usb port into the network of the car
usb in center console...maybe?
84 928 S - SOLD 2012 Cayenne S |
2006 is probably too old for that. My 2004 does not have USB or blue tooth (despite being fully optioned).
I don't. Just listen to the radio or a CD.
