04 cayenne radio issues
Radio screen went dim, now doesn’t work at all. Unit doesn’t “wakeboard” when turning ignition on. Checked power is good, the CAN lines are live. Fiber optic lights up. Fuse on back of radio is fine. Accepts CD but won’t eject. What’s going on. What to do?
My other ride is a C-130J
My ‘05 Cayenne would have all sorts of weird things happen when the battery was going bad. By chance is your battery old?
I had similar radio issues with my 7 year old battery, worth while to check it out.
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic 2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer Previously Owned Art from Stuttgart 2000 Boxster -1983 911 SC Cab -1984 944 N/A Last edited by RNajarian; 10-26-2021 at 07:54 PM.. |
The first thing is the screen was getting dimmer and dimmer until you could hardly see it but the radio still worked, however I could only control volume from the steering wheel. Eventually, nothing worked |
Ugh. Hopefully that’s not the unit going out. Is it the double din radio?
If it were me I would consider swapping out the head unit to one with Apple play. If you are going to spend the money to repair you might as well get an upgrade with Bluetooth.
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic 2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer Previously Owned Art from Stuttgart 2000 Boxster -1983 911 SC Cab -1984 944 N/A |
Information Junky
Check the power and ground(s)
Maybe jumper both and see if things go back to normal.
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
