Administrator
Rennline Cayenne and Macan Product Guide
If you're looking for quality upgrades and parts for your Porsche you will want to check out Rennline's extensive growing product line-up. Find everything including interior exterior trim pieces, suspension and drivetrain components and more! Rennline gives you the high quality components you desire which are designed using cutting-edge technology and high-quality materials to ensure durability and a long life. Check out the items below to find some of these amazing products for your Cayenne and/or Macan!
The list is still GROWING! Stay tuned and check back as more products are added frequently! ![]() |
Administrator
Rennline Mudflap Kits:
Mudflaps are a quick and easy way to protect your vehicle's precious paint from rocks and debris. Our kit comes with four mudflaps and all the needed hardware for a quick and simple installation. These mudflaps are tough, made from weather-resistant plastic, and designed specifically for your Cayenne or Macan for an OEM fit and finish. Cayenne: 9Y0 Cayenne Mudflap Kit (18-23') #REN-E386 958 Cayenne Mudflap Kit (11-17') #REN-E387 957 Cayenne Mudflap Kit (06-10') #REN-E388 Macan: 95B Macan Mudflap Kit (2017+) #REN-E389 ![]() ![]() |
Administrator
Carbon fiber mirrors
Rennline Carbon Fiber Mirror Shells
Rennline's carbon fiber mirror shells are a great way to give your Porsche a subtle yet modern exterior upgrade. Made from high-quality carbon fiber using the latest technology, our mirror shells are designed with the dimensions of the OEM pieces for a factory fit and finish while adding a bit of style. Take your old plastic pieces out and install ours in their place. Installs in minutes reusing the factory hardware. 957 Cayenne #REN-E372 95B Macan #REN-361 ![]() Last edited by Matt at Pelican Parts; 08-05-2024 at 01:50 PM.. |
Administrator
Rennline ExactFit Phone Mounts:
Introducing Rennline's ExactFit Magnetic Phone Mounts – the perfect phone mounting solution. No more flimsy mounts or damaging attachments to your vehicle’s interior. Our tailored mounts fit your specific model, installing easily in minutes. Built with durable metal components for long-lasting reliability and an OEM+ appearance. Porsche Macan (2015+) #REN-PM01-02 Porsche Cayenne 2017-2018) Part#: REN-PM01-13-R Porsche Cayenne 2011-2016 Part#: REN-PM01-05 Porsche Cayenne 2003-2010 Part#: REN-PM01-07 Induction Charger (See "Fitment" for details) ![]() |
Administrator
LED Fog Lights
Modernize and dress up the front end of your Macan or Cayenne with our LED fog lights. These fog lights are designed to be a direct fit replacement of the OEM fog light. The kit includes all connectors, rubber seals, and electrical harnesses for an easy installation. At 1200 raw lumens per side, these projectors will produce a wide, distributed beam that is perfect for night time driving. Sealed Beam LED 1200 Raw Lumens Plug and Play with Factory Fog light Wiring SAE, DOT, and ECE Regulations are all met or exceeded. Replaces OEM part #: 955 631 163 00 Macan 95B/Cayenne 92A (Clear) Part#: REN-EL68-CLEAR Macan 95B/Cayenne 92A (Yellow) Part#: REN-EL68-YELLOW ![]() |
Administrator
LED Turn Signals:
Modernize your Cayenne with an LED flair. These lights are designed to be a direct fit replacement of the OEM Turn Signals. The kit includes all connectors, rubber seals, and electrical harnesses for an easy installation. With a high-powered LED behind the lens, your lights will be more visible in day or night compared to OEM. Cayenne: CAYENNE 957 LED SIDE MARKER Part#: REN-EL79-CLEAR CAYENNE 958 LED SIDE MARKER Part#: REN-EL78-CLEAR CAYENNE 958.2 LED SIDE MARKER Part#: REN-EL77-CLEAR Macan: MACAN 95B LED SIDE MARKER LIGHTS Part#: REN-EL74-CLEAR Last edited by Matt at Pelican Parts; 08-06-2024 at 06:46 PM.. |
Administrator
Porsche Rennline Carbon Fiber Interior Door Trim Kit - Macan 95B.1
Enhance your Porsche Macan 95B.1 interior with Rennline's Carbon Fiber Interior Door Trim Set. Featuring a stylish OEM+ design crafted from high-quality Pre-Preg Carbon Fiber for durability and a sleek appearance. The UV-resistant gloss resin coating maintains its pristine look over time, even when exposed to sunlight. Precision-designed using OEM molds, it ensures a perfect fit. Features - OEM+ Style 2x2 Carbon Fiber with a UV Resistant Gloss Resin Coating Designed using precision molds from OEM parts for excellent fitment. Installs in place of the factory trim Shop Now: #REN-I162 ![]() Last edited by Matt at Pelican Parts; 08-16-2024 at 12:18 PM.. |
Administrator
Porsche Rennline Carbon Fiber Dash Trim Kit - 95B.1
Enhance your Porsche Macan 95B.1 interior with Rennline's full replacement Carbon Fiber Dash Trim Kit. Featuring a stylish OEM+ design crafted from high-quality Pre-Preg Carbon Fiber for durability and a sleek appearance. The UV-resistant gloss resin coating maintains its pristine look over time, even when exposed to sunlight. Precision-designed using OEM molds, to ensure a perfect fit. Features OEM+ Style 2x2 Carbon Fiber with a UV Resistant Gloss Resin Coating Designed using precision molds from OEM parts for excellent fitment. Installs in place of the factory dash trim Shop Now: #REN-I163 ![]() |
Thread Tools | |
Rate This Thread | |
