Go Back   Pelican Parts Forums > Porsche Forums > Porsche Cayenne & Macan Forum
New Throttle Body - Re Code?
Do you need to use an external device to re-code or calibrate a
a newly replaced throttle body? Or is this procedure possible with using a built in process or pattern?
Thank you
2016 958 Base Cayenne
Old 09-11-2024, 03:20 PM
* re-code throttle body
Old 09-11-2024, 03:21 PM
It'll be legen-waitforit
stealthn's Avatar
Why would a throttle body need to be coded? I’m confused
Bob James
06 Cayman S - Money Penny
18 Macan GTS
Old 09-13-2024, 04:27 PM
I have read a few things that state after cleaning or replacing the throttle body in a Porsche Cayenne 958, a re-code/re-learn procedure is required so it functions correctly. I do not know why this is required or if the vehicle can automatically calibrate it. I am hoping an expert here may know.
Old 11-07-2024, 03:26 PM
stealthn's Avatar
Is it a new throttle body?
There is an adaptation just using the key to the on position for one minute then off for 15 seconds that is an adaptation after cleaning and stuff, but not sure about a replaced one. Search for the manual one and try that first?
Bob James
18 Macan GTS
Old 11-11-2024, 09:02 PM
Tags
958 , throttle body
