Go Back   Pelican Parts Forums > Porsche Forums > Porsche Cayenne & Macan Forum
dhrcr911s's Avatar
Somebody tell me why I shouldn't do this
2005 Cayenne S.. 69000 miles, clean carfax, lapis blue with Grey.. I'm facinated. I don't test drive cars, but went ahead and did it anyway.. I can get it for Around $20k..
What are the things to ask and be aware of?? i know the coolent pipe issues, what else??
Bob
SWB 911S 1967 307653S in my fathers garage now
LWB 911T 1971 9111120264 Back in my garage after a lenghty stay in Oregon
Old 08-13-2012, 01:25 PM
dhrcr911s's Avatar
Old 08-13-2012, 01:28 PM
one of gods prototypes
bell's Avatar
Common things to be aware of.....
Brakes are expensive.....
The driveshaft support will fail eventually.....about a grand
You know of the water pipes....
There have been some instances of piston slap showing up in the v8 models, more so in Europe....but I have seen 2 of them this year, it'll sound like a lifter but is slap....
If you can afford the maintenance then go for it....stay on top of the the service....
I have seen better deals, like 15-18k for a comparable truck....if you can get it on a lift you could check it closer...or slide underneath....
Brought to you by Carl's Jr.
Old 08-13-2012, 04:57 PM
Porsche Owner
mark4ton's Avatar
IMO price is a little more then market for what looks like a standard cayenne s
1987 Carrera - 2008 Cayenne Turbo
Old 08-13-2012, 05:21 PM
dhrcr911s's Avatar
Thanks Guys.. I apprciate any and all input.. Bob
Old 08-13-2012, 07:13 PM
jrumiano's Avatar
Known issues on 2003 - 2006 Cayenne S and turbo models.
* Plastic coolant pipe replacement to metal, DIY for about $600 for the kit (dealer $2K -$3K depending on the dealer)
* Cardan shaft (drive shaft), several companies are rebuilding shafts with new bearing for less than $400 and replacement can be a DIY.
* Brakes are only expensive if you take it to a Porsche dealer. DIY for pads and wear sensors around $150, add another 400-500 bucks if you replace the rotors.
* Original spark coils have a habit of cracking and should be replaced. With 70K miles the plugs should have already been replaced so the coils may have also been replaced.
$20K for a 2006 w/70K from a private party is not that far off the mark. (Dealer pricing would be ~$24K)
Hopefully this information helps.
John
Old 08-14-2012, 04:29 PM
