Go Back   Pelican Parts Forums > Porsche Forums > Porsche Cayenne & Macan Forum
Send a message via Yahoo to elo168
Draining gas
How do you drain the gas from a Cayenne?
Old 07-25-2013, 10:01 AM
Mike80911's Avatar
I purchased a hand operated transfer pump from Harbor Freight it was inexpensive and works very well You stick one hose down through the filler neck and put the other hose into a can and pump.
89 930 Cab Black
11 Cayenne
Old 07-25-2013, 01:25 PM
Are you sure you can still do it on the newer models?
Cause I heard there is a net on filler neck now to prevent crap to get in.
Old 07-25-2013, 02:16 PM
Mike80911's Avatar
You might be correct I am not sure about that. Are you draining the gas to swap the fuel pumps? I did mine with the tank at 3/4 and did not drain it
89 930 Cab Black
11 Cayenne
Old 07-27-2013, 02:17 PM
Ok found out how to do it.
There is a release valve in the engine area.
Close to the fire wall on the driver side.
You need a special tool.
Old 07-29-2013, 03:43 PM
