Go Back   Pelican Parts Forums > Porsche Forums > Porsche Cayenne & Macan Forum
roadster49's Avatar
915 transmission will not go into any gear
My 83 911 sc won't shift into any gear. I changed the clutch cable and helper spring. Checked the shift coupler. When I try to go into reverse it grinds. Any suggestions are welcome.
Old 07-23-2016, 08:16 PM
Porsche's Love-em Live-em
IF there is no excessive play from; cable, sifter, or the rear coupler play you may have a frailer [bending] of the release bearing fork. It does happen. If so the clutch release system will feel Rubber band like.
Old 07-23-2016, 10:54 PM
What happens if you try to put the car in reverse, depress the clutch and then start it? This will tell you if your clutch has a problem...if the car tries to move when you hit the starter, you've got clutch issues, if the car doesn't, it's likely in the gearbox.
Old 07-25-2016, 08:38 AM
roadster49's Avatar
It will go into reverse from an engine start. Clutch must be dragging
Old 08-06-2016, 01:08 PM
You got it!
Old 08-29-2016, 09:59 AM
