Go Back   Pelican Parts Forums > Porsche Forums > Porsche Cayenne & Macan Forum
2008 Cayenne S engine shot - rebuild or replace?
First, my apologies - I hate registering on a forum and immediately start asking questions, but I'm in a bit of a bind. Here's why:
That's one of my cylinders. My mechanic removed one cylinder head and then called me - the other two that aren't TDC are the same, so I'm assuming that a) the rest is the same, and b) whoever was the previous owner was an idiot and floored it before the engine was decently warmed up.
I have two questions - rebuild or buy a second hand engine? Both come with risks, I'm especially anxious about resleeving an aluminum block, not sure we have anyone in Toronto, Canada (where I live) with a good reputation.
The second one - there's a GTS engine for sale on ebay. The seller says it'll fit an S, and advertises so. My mechanic reckons it's going to also require transplanting electronics. Who is right?
Thanks in advance, and my apologies for barging in.
Old 05-31-2016, 02:18 PM
I think Jake Raby at Flat 6 Innovations can help. Here's the thread at rennlist.
2008 cayenne turbo engine wall scored - Rennlist Discussion Forums
Old 05-31-2016, 04:01 PM
Thanks - reading now
Old 05-31-2016, 04:59 PM
Thanks for the link - I know a lot more now. Given the fact that I cannot work around the issue with the cold, I may replace the engine and sell it, then get a turbo which seems to not have the "do not drive in Toronto in winter" issue :-). Still leaves me wondering whether the GTS block will fit. Research indicates is the air intake and the ECU that give the extra PS, I think that a larger air intake shouldn't hurt with the regular S ECU. But spending $$$$$ to try it out may not be the smartest way forward. I guess I'll see how nice the local Porsche dealer is with handing out info...
Old 05-31-2016, 07:01 PM
Why wouldn't you just fit the GTS engine block and use your existing manifold and plenum? Then all the electronics would be the same.
Sent from my SM-G935F using Tapatalk
Old 06-10-2016, 02:13 AM
And that's exactly what I'm moving forward with - block should be on its way any day now
(and then sell the car before it gets cold again over here)
Old 06-10-2016, 06:10 AM
Can't you get one of the cab heaters used in Europe? My CTTS is left-hand drive from Germany and has the heater. It works very well and can be set up on a daily timer to warn up the engine block and cabin.
Old 06-10-2016, 01:31 PM
My car is parked on the street, at the other side of my house, so I cannot plug a heater in, alas. Because yes, that would be the best option and less hassle than selling the car and getting a new one ;-)
Old 06-11-2016, 08:02 AM
No power required. The factory fitted heater runs off petrol and can be set on timed start and for 30 minute duration. Porsche call it a parking heater.
Old 06-11-2016, 08:36 AM
I also have a BMW X5 and that has a heater but that one is diesel fuel. I'm sure you could retro fit one from other makes if you wanted to.
Old 06-11-2016, 08:37 AM
No power required. The factory footed heater reruns off petrol and can be set on timed start and for 30 minute duration.
Interesting - that'd be ideal. Do you have a link? I'm originally from the Netherlands, where we don't need such things so I'm completely oblivious here
Old 06-11-2016, 09:04 AM
I have uploaded two documents, one being 5 pages from the cayenne hand book, and the other a workshop manual for the parking heater.
http://www115.zippyshare.com/v/iUoCxfbF/file.html
http://www115.zippyshare.com/v/oiEyhoKR/file.html
I'm sure that if you wanted to you could buy the required parts from a UK or European dismantlers/breakers yard.
Old 06-11-2016, 12:29 PM
Thanks a million! Gonna talk to my mechanic on Monday, with the engine out shouldn't be too hard to slot it in :-).
On to ebay.co.uk/ebay.de...
Old 06-11-2016, 02:02 PM
To follow up: I got the GTS engine, and it's running. There's only one little problem left, apparently the GTS engine has a slight difference - there's a fuel temp sensor on the new engine in the back that isn't there on my (slightly older?) engine, no spot to connect the sensor on the ECU, and - the fun bit - it not being connected triggers the engine light. Hope my mechanic will figure out what to do ;-)
Old 07-27-2016, 06:50 AM
