Go Back   Pelican Parts Forums > Porsche Forums > Porsche Cayenne & Macan Forum
Front Door Drupe Adjustment
Does anyone knows the procedure how to adjust Door drupes?
I know the way to insert shim at lower bolt for hinge but unfortunately the bolt is too tight and gave up to loose the bolt. I think the adjustment can be done for the hinge main body side bolt but not sure. It is not technical item but need to fix it.
Old 12-17-2016, 06:24 AM
I tried easy way to compensate Door droop.
Juck up Door end bottom very carefully using wood chip and keep the height slightly higher than it should be. Then removed the tool.
It worked fine for me and still looks ok after several months.
Old 03-13-2017, 06:07 PM
I have the same problem, can someone post pictures and maybe a short write up in this? Alex
Its easier asking dumb questions than fixing dumb mistakes
1974 Porsche 911 Coupe, RSR Project
1976 Porsche 911 Targa, Black
1986 Porsche 911 Carrera, Black
2006 Porsche Cayenne S, Black
Old 03-27-2017, 06:11 PM
