Front Door Drupe Adjustment
Does anyone knows the procedure how to adjust Door drupes?
I know the way to insert shim at lower bolt for hinge but unfortunately the bolt is too tight and gave up to loose the bolt. I think the adjustment can be done for the hinge main body side bolt but not sure. It is not technical item but need to fix it. |
![]() Juck up Door end bottom very carefully using wood chip and keep the height slightly higher than it should be. Then removed the tool. It worked fine for me and still looks ok after several months. ![]() |
I have the same problem, can someone post pictures and maybe a short write up in this? Alex
Its easier asking dumb questions than fixing dumb mistakes 1974 Porsche 911 Coupe, RSR Project 1976 Porsche 911 Targa, Black 1986 Porsche 911 Carrera, Black 2006 Porsche Cayenne S, Black |
Thread Tools | |
Rate This Thread | |
