I fitted a Subaru transaxle and it fits!
So im going to be doing so testing for a new gearbox thats going to be offered as an alternative for the 901 and 915. Smoother shifts, cheap rebuilds, cheap clutches, better ratios. I have just fitted it to my sc and ill be testing it in the upcoming months. I will be putting about 400hp through it and report back. Its fitted with CNC'd 930 output shafts and has sightglass to make things easy. Along with an LSD
PRO Motorsports
How will you convert it for rear engined use?
Flip the ring and pinion? Or run it upside down? Or just live with one forward gear and 5 reverse gears? ![]() |
Good engineering skills. I have trouble even making the correct stuff work. I hope it all works out well for you.
Functionista
Stout.
What she weigh?
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
Interesting. I look forward to hearing more.
Sent from my iPhone using Tapatalk |
Looks massive. Weight?
300hp 1800lbs is the goal
Subbed for for when I fit mine. You used subarugears swap parts I'm assuming? Looks great.
The '66 912 Bastardization project has begun. Note to PO's: LAY OFF THE FREAKING BONDO!!!! The science was settled: Earth was flat. Galileo : Flat Earth denier. ![]() |
I would rather be driving
This has been done before.
Do you have a solution for the select shaft that has to go above the torsion tube? This means a hole in the hump on the rear seat pans and a linkage above the tunnel. Not sure many will be willing to drill that hole. I put a Suby drivetrain in my 914. Rigged a cable shift and it was so much better than the 914 gearbox. 4 times the stock HP value didn't hurt either.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
55kg
55kg Quote:
which way does a stock Subaru gearbox turn when put in a 911 unmodified ?
My guess is more reverse gears than you need as a Subaru motor runs the "correct" way and not reverse like a Corvair ![]()
looking for information about old VW Coach built based sports cars, or photos and stories from the past , At one time many of these got confused as "Porsche prototypes" including the one restored at Hill and Vaughn in Santa Monica |
Subarugears make a reverse r&p gear to get 5 forward gears
gearhead
Not really stout. In the WRC days it was called the glass gearbox. Once the cars started going over 350hp they had major reliability concerns. The gears themselves are no wider than 915 gears. I've ripped teeth off with a stump-pulling 150 AWHP.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
I have experience with high power in the 5 speed boxes. It can take 300 WHP as long as you don't launch from a dead stop. The 6 speed STI gear box can take all kinds of abuse though. It is about 100 lbs heavier and much larger.
gearhead
We're putting 800whp through the 6spd boxes. It's a totally different beast.
fit some blast plates. problem solved
Can you post us some picks of the car, what year....etc?
Very interesting. |
gearhead
Blast plates only address case flex. They won’t make the gears wider.
What ever happened to this build?
What do you wanna know. It works tho im running a new shifter now
