Go Back   Pelican Parts Forums > Porsche Forums > Porsche Engine Conversion Tech Forum
LinkBack Thread Tools Rating: Thread Rating: 3 votes, 2.33 average.
The 01X box is now fully installed with axles, and shifter connected. YAY 6 SPEED and super low crusing revs
pictures to follow, also finally rigged up new proper intake plumbing to move the filter in the old power steering oil cooler location.
Old 05-20-2020, 06:33 AM
Sorry havent posted much for a while working crazy hours for work and i started on my spring tune ups for customers 944, 968s etc. on #2, now and about 5 in line to do.
car still runnign and driving but is parked until i can dial in some final adjustments and than take it for an allignment, i have my intake plumbing done up just have to actually install it and extend the wiring harness for the MAF. leaks are all fixed Thankfully got tired of seeing some wet spots.
and all the needed parts for final work has arrived, new rebuilt torque tube is awaiting install. new TOB, new custom Intermediate bearing and race ready. new Heavier duty clutch. wiring for speedo is awaiting install aswell.
news to come !
Old 06-02-2020, 08:41 AM
Any more updates please?
Old 12-13-2020, 05:10 AM
the car is still running and moving, i have readjusted the steering setup a few times to try and tone down the bump steer etc, what are you interested in, i have 6 or 7 other projects and i have customers always getting me to do work for them so my stuff gets slowed down.
Old 01-10-2021, 06:01 AM
Fun update after countless hours of trying to diagnose my non functional speedometer I have a very accurate Speedo! In the vw cluster!
I utilized the 968 abs run Speedo signal. I however rewired it so the rear wheel runs the Speedo and not the front. Also much easier to work and calibrate while the cars on the lift.
Hazah!!
Also steering is pretty much dialed it. Just want to try and loft the back to balance it out. Than she should be golden.
Cheers.
Old 01-25-2021, 07:54 AM
That’s great progress. What a cool build!
Old 04-17-2021, 02:21 AM
suspension is sorted marty, its been driving arround for a bit, i just have to make time to go to a race shop to get a proper allignment done
Old 04-18-2021, 03:39 PM
just a casual saturday :)
Old 05-01-2021, 04:08 PM
What mpg are you getting now btw? We also need to see this thing do some pulls!
Old 05-11-2021, 01:03 PM
A new update, so ive put about 900km on this thing this summer and had 2 breakdowns minimal problems but what else is a project but trial and error !
I swapped in a wizard Radiator yesterday, the diesel really likes to run 90 degrees even, where as most other motors alternate and run a little hotter, i was seeing some higher temps on really hot days closer to 97' even. so swapped in a bigger rad and fixed my cooling fan resistor pack.
my highway cruising at about 120km/h hits the tach at about 2300rpm in 6th gear.
in theory i think i should be able to hit my goal of 1500km/tank roughly 5l/100km but ill have to drive like a sain person... 28psi of pretty instant boost is quite addictive,
ill update some more later in the fall !
Old 10-06-2021, 05:43 AM
David at Pelican Parts
Guest
Posts: n/a
Roll Coal! I love the idea of your build. Updates?
Old 12-16-2021, 01:22 PM
put about 1k km on it this, summer/ just had a baby sp slow winter, but am working on a custom length shock setup for the front!
Old 12-28-2021, 08:09 PM
passed the 2k km mark last week!
have some new custom front shocks to mount and revamped steering tie rods in the works! but enjoying it without wanting to bring her in the shop! 28psi of boost is addictive hehe
Old 06-07-2022, 03:46 PM
Hot beans man!!! Congratulations on this epic swap!
1982 924 *Audi V8 Swap In Progress*1985.5 944 NA *3.0L 16V swapped* 1987 944 Turbo *3.0l 8V*.
1987 944 NA 1991 944S2 2001 VW Passat, *Built 1.8T* 1985.5 944NA Sold to younger brother
1983 944NA Gave to my Dad for being Awesome.
Old 06-09-2022, 12:39 PM
New shocks installed @
Catch can drained..
First oil change done.
Fixed boost leak also.
Might have to put in my stronger clutch.. it doesn't like 5th & 6th gear pulls under 2500rpm hehe woops...
Drives like a toy @
Slowly.and surely will.work.on rigging functional AC. And have teeter tattered on idea t9mput back power steering. Since it's for regular driving snf I have to park it in our work lot everyday.. it is a workout.. especially at.5am..
2500km down !!,
Old 06-28-2022, 07:25 PM
Excellent updates!
Old 09-01-2022, 03:38 PM
so a sad temporary update...
before heading to 944fest the tandem pump went out, overnighted one from kerma. got it in, drove to 944fest in ohio!
made it there!
tracked it... blew up the clutch. swapped the clutch on the grounds, pinched some wiring, fixed wiring..
70 miles into return drive. the motor went...
a lot of variables but likely need a head rebuild.
engine is currently out to be fixed but too much going on currently to open it up and see what went wrong.
will update when shes back vroom vroom down the road !
Old 09-27-2022, 06:16 PM
Administrator
Matt at Pelican Parts's Avatar
Love this build! Post up more pictures when you have the car back together!
-Matt
Old 09-29-2022, 04:16 PM
Hello. I put my track car on a 924 V.A.G this summer. 1.8L on. Familiar solutions were visible. I have also previously installed a 1.9tdi on a Phaeton. The 944 2.0TDI is also planned next. Strength and endurance to you.
Old 11-06-2022, 09:40 AM
Do you think the 28lbs of boost might have something to do with the engine failure?
I've got a Malone 1.5 tune on my Passat B5.5 wagon (2.0 tdi) and I'm on my third clutch, but it seems to be holding well. The engine runs sweet. If I want to drive at 60 mph I can get ~1100 km/tank. But who wants to drive at 60 mph?
Good luck,
hughc
Old 11-06-2022, 11:19 AM
