Go Back   Pelican Parts Forums > Porsche Forums > Porsche Engine Conversion Tech Forum
klink's Avatar
'07 Cayman 3.4L into an '03 Boxster S
Motor has been in car running with an '07 Cayman motor harness adapted to the original 7.8 DME. DME has been reprogrammed. It would not smog. So starting over. I've installed an '06 Cayman S engine harness and I have a used 7.8 DME out of an '06 Cayman with it''s VIN #. I have searched high and low for the diagrams for the two chassis plugs in the motor harness so they can be adapted to the Boxster. I would appreciate any insight as to where I might find these. Thank you in advance!
Old 08-07-2020, 09:05 AM
Contact Tims944 here on Pelican. he may be able to get you the wiring/plug diagrams. He has helped me a lot with diagrams.
1982 924 *Audi V8 Swap In Progress*1985.5 944 NA *3.0L 16V swapped* 1987 944 Turbo *3.0l 8V*.
1987 944 NA 1991 944S2 2001 VW Passat, *Built 1.8T* 1985.5 944NA Sold to younger brother
1983 944NA Gave to my Dad for being Awesome.
Old 08-07-2020, 01:58 PM
klink's Avatar
Thank you for that. I appreciate it!
Old 08-07-2020, 03:24 PM
