Porsche Boxster 996/997 gearboxes
Type: G86/00 (97-99), G86/01 (00-04)
OEM for: Porsche Boxster 986 1997-2004 Description: H pattern 5 speed manual transaxle w/synchronized reverse Limited Slip Differential: Not offered Transmission controls: Shift cables Clutch: Hydraulically assisted push clutch 1st gear 3.50 2nd gear 2.118 3rd gear 1.429 4th gear 1.029 G86/00 (1.09 G86/01) 5th gear 0.79 G86/00 (0.838 G86/01) Final Drive 3.89 G86/00 (3.56 G86/01) This is an Audi FWD 5 speed gearbox with different ratios. Type: G86/20, (00-04) OEM for: Porsche Boxster S 986 Description: H pattern 6 speed manual transaxle with Borg Warner synchromesh and synchronized reverse Limited Slip Differential: Not offered Weight (approx): 175lbs Oil capacity (approx): 2.7L API classification GL5 75/90 Speedometer: None Transmission controls: Shift cables Clutch: Hydraulically assisted push style clutch 1st gear 3.818 2nd gear 2.20 3rd gear 1.516 4th gear 1.216 5th gear 1.024 6th gear 0.841 Final drive 3.444 This is a Getrag gearbox than can handle a lot more torque than the 5 speed. Type: G96/00 (99-01), G96/01 (02-05) OEM for: Porsche 996 Carrera 2 (C2) Type: G96/30 (99-01), G96/31 (02-05) OEM for: Porsche 996 Carrera 4 (C4 AWD) Description: H pattern 6 speed manual transaxle with Borg Warner synchromesh and synchronized reverse Limited Slip Differential: 40/65 LSD optional equipment Weight (approx): 175lbs Oil capacity (approx): 2.7L API classification GL5 75/90 Speedometer: None Transmission controls: Shift cables Clutch: Hydraulically assisted push style clutch 1st gear 3.818 2nd gear 2.20 3rd gear 1.516 4th gear 1.216 5th gear 1.024 6th gear 0.841 Final drive 3.444 Very good strong Getrag gearbox. Type: G97/01 (Manufactured by Aisin) OEM for: Porsche 997 Carrera 2 2005-2008 Description: H Pattern 6 speed manual transaxle with cone synchromesh and synchronized reverse Limited Slip Differential:standard equipment (S model only) Weight (approx): 170 lbs Oil Capacity (approx): API classification GL5 75/90 Speedometer: None Trans controls: Shift cables Clutch: Hydraulically assisted push clutch, single plate 1st gear 3.91 2nd gear 2.32 3rd gear 1.61 4th gear 1.28 (1.31 S model) 5th gear 1.08 6th gear 0.88 Final drive 3.44 Made in Japan by Aisin.Also good strong gearbox. |
i have talked to Ben at Retrosport here in the US about taller 4th/1.04, 5th/.80, gears for the 996 trans. They/Albins already make a taller 6th/.0625. he talked to albins and they said yes if we get a group buy of at least 10 of each. i have also talked to Roger at CMS Transmissions about it. currently cms is building my land speed/top speed gearbox... yes i already have the 3.00 ring and pinion. but want to see 250-260mph ultimately. if interested in a taller 4th and 5th gear contact
ben or Roger
1980 Euro 911 g9688 LSx chassis car 1982 Euro 911 3.0 1987 Ferrari 308 GTB 2006 H1 Wagon Last edited by Cobalt964ruf; 04-23-2025 at 10:14 AM.. |
I put a taller gear in my 89 911 LS1 to help with cooling on the highway and a nice drop in RPM's. Certainly helped. It does have a whining noise that one notices when driving which is normal for any aftermarket gears.
1989 911 LS1 |
