Go Back   Pelican Parts Forums > Porsche Forums > Porsche Engine Conversion Tech Forum
Porsche Boxster 996/997 gearboxes
Type: G86/00 (97-99), G86/01 (00-04)
OEM for: Porsche Boxster 986 1997-2004
Description: H pattern 5 speed manual transaxle w/synchronized reverse
Limited Slip Differential: Not offered
Transmission controls: Shift cables
Clutch: Hydraulically assisted push clutch
1st gear 3.50
2nd gear 2.118
3rd gear 1.429
4th gear 1.029 G86/00 (1.09 G86/01)
5th gear 0.79 G86/00 (0.838 G86/01)
Final Drive 3.89 G86/00 (3.56 G86/01)
This is an Audi FWD 5 speed gearbox with different ratios.
Type: G86/20, (00-04)
OEM for: Porsche Boxster S 986
Description: H pattern 6 speed manual transaxle with Borg Warner synchromesh and synchronized reverse
Weight (approx): 175lbs
Oil capacity (approx): 2.7L API classification GL5 75/90
Speedometer: None
Clutch: Hydraulically assisted push style clutch
1st gear 3.818
2nd gear 2.20
3rd gear 1.516
4th gear 1.216
5th gear 1.024
6th gear 0.841
Final drive 3.444
This is a Getrag gearbox than can handle a lot more torque than the 5 speed.
Type: G96/00 (99-01), G96/01 (02-05)
OEM for: Porsche 996 Carrera 2 (C2)
Type: G96/30 (99-01), G96/31 (02-05)
OEM for: Porsche 996 Carrera 4 (C4 AWD)
Limited Slip Differential: 40/65 LSD optional equipment
Speedometer: None
1st gear 3.818
2nd gear 2.20
3rd gear 1.516
4th gear 1.216
5th gear 1.024
6th gear 0.841
Final drive 3.444
Very good strong Getrag gearbox.
Type: G97/01 (Manufactured by Aisin)
OEM for: Porsche 997 Carrera 2 2005-2008
Description: H Pattern 6 speed manual transaxle with cone synchromesh and synchronized reverse
Limited Slip Differential:standard equipment (S model only)
Weight (approx): 170 lbs
Oil Capacity (approx): API classification GL5 75/90
Speedometer: None
Trans controls: Shift cables
Clutch: Hydraulically assisted push clutch, single plate
1st gear 3.91
2nd gear 2.32
3rd gear 1.61
4th gear 1.28 (1.31 S model)
5th gear 1.08
6th gear 0.88
Final drive 3.44
Made in Japan by Aisin.Also good strong gearbox.
Old 05-19-2015, 05:12 AM
i have talked to Ben at Retrosport here in the US about taller 4th/1.04, 5th/.80, gears for the 996 trans. They/Albins already make a taller 6th/.0625. he talked to albins and they said yes if we get a group buy of at least 10 of each. i have also talked to Roger at CMS Transmissions about it. currently cms is building my land speed/top speed gearbox... yes i already have the 3.00 ring and pinion. but want to see 250-260mph ultimately. if interested in a taller 4th and 5th gear contact
ben or Roger
1980 Euro 911 g9688 LSx chassis car
1982 Euro 911 3.0
1987 Ferrari 308 GTB
2006 H1 Wagon
Old 04-22-2025, 02:58 AM
Yan2947's Avatar
I put a taller gear in my 89 911 LS1 to help with cooling on the highway and a nice drop in RPM's. Certainly helped. It does have a whining noise that one notices when driving which is normal for any aftermarket gears.
1989 911 LS1
Old 04-22-2025, 04:40 AM
