Sharpbuilt Australia
I have been trying to contact Mike Sharp for about a week now by email with no response. Anyone know 1. Is he still in business and 2. If so, what the price of his 911-style shroud kit is?
And if anyone knows of an alternative email address to the one on his web site please pass it along. Thanks- |
he's usually prety slow to answer his email, but he usually does
if you want I'll email you the price/info sheet on the 911 shroud VB |
Thanks for the prices VB. I received a reply from Mike Sharp shortly after I received your email. It looks like his prices have gone up . For anyone interested, here are the prices for his kit:
Fanshroud with 4 lower cylinder covers (fiberglass) Alternator stand full size. Stand base plate. Oil fill tube and bracket accepts type IV & III oil fill funnel. Billet crank pulley 5" Porsche 911 size. Fuel pump block off plate. Crankcase breather fitting. Hardware and fitting instructions. US $420 With Engine bay sealing tin fiberglass) $510 SHIPPING AIRMAIL $ 80 Porsche style oilcooler air duct(fitted)$ 78 Pilot bush (mates type IV flywheel to type I input shaft) $ 12 Header pipes Sedan $ 95 Header pipes Baja $ 95 |
fuel pump block off plate?
correct me if I'm wrong, but I believe the type4 engine uses an externally mounted electric pump. |
That one had me a little confused too. Maybe there's some version of later bus motor that had a mechanical pump? I don't know.
The T4 engines that came with dual carbs (74 bus I think is one) had a mechanical fuel pump mounted on the block.
| All times are GMT -8. The time now is 07:50 AM. |
