Go Back   Pelican Parts Forums > Porsche Forums > Porsche Engine Conversion Tech Forum
Sharpbuilt Australia
I have been trying to contact Mike Sharp for about a week now by email with no response. Anyone know 1. Is he still in business and 2. If so, what the price of his 911-style shroud kit is?
And if anyone knows of an alternative email address to the one on his web site please pass it along. Thanks-
Old 04-26-2000, 05:33 AM
ViolentBlue's Avatar
Send a message via ICQ to ViolentBlue
he's usually prety slow to answer his email, but he usually does
if you want I'll email you the price/info sheet on the 911 shroud
VB
Old 04-26-2000, 06:10 AM
Thanks for the prices VB. I received a reply from Mike Sharp shortly after I received your email. It looks like his prices have gone up . For anyone interested, here are the prices for his kit:
Fanshroud with 4 lower cylinder covers (fiberglass)
Alternator stand full size.
Stand base plate.
Oil fill tube and bracket accepts type IV & III oil fill funnel.
Billet crank pulley 5" Porsche 911 size.
Fuel pump block off plate.
Crankcase breather fitting.
Hardware and fitting instructions. US $420
With Engine bay sealing tin fiberglass) $510
SHIPPING AIRMAIL $ 80
Porsche style oilcooler air duct(fitted)$ 78
Pilot bush (mates type IV flywheel to type I input shaft) $ 12
Header pipes Sedan $ 95
Header pipes Baja $ 95
Old 04-27-2000, 10:10 AM
fuel pump block off plate?
correct me if I'm wrong, but I believe the type4 engine uses an externally mounted electric pump.
Old 04-27-2000, 08:30 PM
That one had me a little confused too. Maybe there's some version of later bus motor that had a mechanical pump? I don't know.
Old 04-28-2000, 04:46 AM
The T4 engines that came with dual carbs (74 bus I think is one) had a mechanical fuel pump mounted on the block.
Old 05-02-2000, 08:28 AM
