Bug -> 944, rear suspension swap
I bought the disc brake setup from a 944 to put on my bug, I got it through a local parts yard (who got it from another one half a country away) so even though I didn't ask for the rear trailing arms, I ended up with them.
This is all fine by me because I didn't realise that the E-brake assembly was part and parcel with the trailing arms. so I've come out ahead. the trailing arms are almost a direct swap with the stock units, so I'm told. I thought I'd might as well use them. I'd like to hear from someone who's done this swap, and hear tyhe pitfalls and suggestions they have. also I'd like to hear what anyone has to say bout the E-brake setup, whats the best way etc. |
Go to The Cal Look Forum: http://www.insidetheweb.com/mbs.cgi/mb389716 and write a post that asks for "Mike Ghia". He will answer your post or someone will tell you how to find him. He is priceless to talk to and a skilled veteran. He used to have a site set up for the 944 conversion. Tell him Elf sent you.
actually I have talked to him, and I have the problem all ironed out already.
vb |
