Go Back   Pelican Parts Forums > Porsche Forums > Porsche Engine Conversion Tech Forum
generator stand gasket
I am installing a new generator stand and I don't know which way the baffle goes.
It's a type 1 volkswagen
Old 12-23-2007, 02:43 PM
Use a thin coat of a sealer (e.g., Permatex) before placing down the a gasket, another thin coat of sealant, the louvered metal filter (which prevents blowback), another thin coat of sealant, and finally a second gasket.
Note: The louvers in the metal filter should be down with the flat side of the louvers facing the flywheel (toward the front of the car).
Put a thin coat of sealant around the edges of the second gasket, then install the pedestal over the four uupright studs in the engine block.
Secure the alternator pedestal with 13mm nuts and washers. Tighten the nuts securely.
Old 01-03-2008, 09:03 AM
+ what ljowdy says.
go to the
www.thesamba.com
www.shoptalkforums.com
These are two of the best ACVW sites on the web.
Old 01-04-2008, 10:50 AM
