Go Back   Pelican Parts Forums > Porsche Forums > Porsche Engine Conversion Tech Forum
Thanks pkabush,
My plan is twins for a few reasons, The 993 heat exchangers for better flow and true dual out exhaust which also helps in the packaging my frame allows. More importantly I have been a dual turbo fan since a kid staring at Gale Banks engines in magazines.
I am very budget minded as this is my work truck and need to rationalize that, so no exotic action, I am cruising craigslist for 996 TT stock take-offs and such.
I have a spare motor that ate some metal so plan to open that up and use it as the future turbo candidate, idea so far is stock 3.2 specs with after market E.C.U with Knock sensors ect.
Will post up on turbo forum when I am ready to formulate a solid plan, could be years at my pace
Old 04-08-2019, 07:26 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #181 (permalink)
porsche powered mid-engine double cab
Still on the lift getting more optimizing done.
went with a hollow splined sway bar for the front and welded in mounts in the rear to run stock 944 sway bars, starting with 16mm bar from a S2 using mounts from Lindsey Racing, also bought mounts for 14mm bar I have to tune down if needed.
Opening up front air intake for new oil cooler location, lots left here to do including some sheet work for ducting and I plan on casting a aluminum frame for bumper opening to attach stainless screen.
Old 07-05-2019, 10:57 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #182 (permalink)
Mostly finished the D.C. suspension during this last session on the lift.
Have some fine tuning to do, but feels good on the road, need to autocross it to check balance.
Front suspension specs: wheels O.Z Fittipaldi 8.5” x 17”,tires 235/40/17
928S4 upper and lower arms, spindles, Brembo calipers, Rabbit rack&pinion
Bilstein coil-overs 700# springs, 1.25” hollow splined sway bar .188” wall.
Rear suspension specs: wheels O.Z. Fittipaldi 9”x17”, tires 255/40/17
944S2 torsion housing, stock torsion springs, early offset 944 aluminum arms, S2 Brembo calipers. 1.5 ratio rocker arms connecting to Bilstein coil-overs 600# springs, 16mm 944S2 sway bar.
Old 07-20-2019, 09:25 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #183 (permalink)
jadewombat's Avatar
Sweet.
'66 11-window VW Bus (Fuel-injecter'd Super-1600, IRS, disk brakes, MB CLK rims)
Old 07-22-2019, 10:06 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #184 (permalink)
