-   Porsche Engine Conversion Tech Forum (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/)
-   -   89 911 LS1 Conversion (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/556905-89-911-ls1-conversion.html)
Yan2947 01-12-2015 05:32 PM
Just to update:
The new Guard 5th gear is in and all is back together. Took the car on a 20 mile ride. The gear noise is not very noticeable. I certainly can here it but nothing at all to worry about. The car drives great with a large reduction in rpms!
At 3200 rpms I am at 100 MPH
At 3500 rpms I am at 110 MPH.
This will solve any rise in radiator temps on the highway. Next step is to create my heating for the car. The air conditioning works wonderful but I have no heat to help defrost the windows!
Mitch Leland 01-12-2015 09:46 PM
Electrical question on a 997...
I had a PM from someone who was asking about hooking up an LS motor in a 997. For whatever reason his question has gone South and lost in cyber space. If you're out there, please write me again.
Thanks,
Yan2947 04-24-2015 06:31 PM
I finally have heat! I haven't attached the planned fan on my heater core yet. I only had my footwell blowers to pull the heat in through the stock heater ducts and it worked! I had heat tonight and it was pretty warm. The heater cores attach directly to the heater duct ends right at the flapper with a Spring disappeared for a couple days here in NY so I was able to test the system a little and so far so good.
I also took my car out on the highway for 40 miles to make sure I would break any lines tomorrow morning. I am going to watch the races at Lime Rock and will bring my car in case anyone else is there...
Once again I tested the RPM and temps and could not get above 190 degrees but it is cold outside
3000 rpm in 5th 94mph (assumed and theoretical)
3500 rpm in 5th 111mph (assumed and theoretical)
4000 rpm in 5th 125mph (assumed and theoretical)
Here is a photo of my heater setup. I know that a lot of things in this build are big bucks so this is my two cents on a heater system that is not so "big bucks"... and seems to work so far. Some of the fittings were changed in the final fitting to get the correct fit with the hoses.
http://forums.pelicanparts.com/uploa...1429925232.jpg
And I didn't use the fan setup on the left side yet. I wanted to see if the footwell blowers would be enough. The tip of my heater core setup goes into each of the wheel wells. (I have two of these in total - one on each heater duct) I could add a 90 or a 270 degree silicone hose at the end of the heater core to point the air that is coming into the core towards the front of the car or front of the wheel well...
Yan2947 05-03-2015 05:43 PM
A nice day driving the beast!
http://forums.pelicanparts.com/uploa...1430700123.jpg
http://forums.pelicanparts.com/uploa...1430700156.jpg
With my new 17" Euromeisters!
mkingham 05-04-2015 10:29 AM
sweet heater core setup
Hi,
Man that heater setup is way cool. Did you fabricate that yourself? Can you upload more photos of how you mounted it?
Thanks, Mike
Yan2947 05-04-2015 12:01 PM
Hey Mike,
you need two of these:
2 25" 4"x 6" Turbo Barrel Water Liquid to Air Intercooler Aluminum | eBay
and two of these:
Black 2 25" 2 1 4" to 2 5" 90 Degree Reducer Silicone Hose 57 63mm Pipe Coupler | eBay
along with some hose clamps.
http://forums.pelicanparts.com/uploa...1430765593.jpg
http://forums.pelicanparts.com/uploa...1430765614.jpg
If you have footwell blowers you don't really need a fan at the end of the intercooler. The intercooler is acting just like a heater core. Perhaps someone can fabricate a better one but it really works. It certainly keeps the windows clear from dew and fog. I think it would keep ice off also but I haven't tried it in the dead of the winter. It would be great if there was room to mount it somewhere on the RH engine cradle... Mine has enough room to reach at an angle to the edge of the wheel well right near the rear strut. On the side (driver's side) with the water pump the return of the intercooler shoots back just before the water pump which pulls the coolant back to the motor. On the side where the coolant leaves the motor I tee off and send 3/4 hose to one barrel intercool and the other tee to the other intercooler. Both returns from the intercooler meet at a tee just under the water pump and go back into the return line from the radiator.
Yan2947 05-04-2015 12:10 PM
Here are some photos of the install...
http://forums.pelicanparts.com/uploa...1430766328.jpg
http://forums.pelicanparts.com/uploa...1430766345.jpg
The wiring took a little bit of work and help to figure things out. Since most of the wires in the engine compartment that dealt with the engine fan had been cut I had to figure out which wire (yellow) triggered the fan previously by pulling up the levers between the seats. That triggered wire then powered a black wire that went back to my manual dial and energized the footwell blowers. I had a thread here:
http://forums.pelicanparts.com/porsche-911-technical-forum/854351-footwell-blower-89-911-operating-question.html
regarding the wiring.
mkingham 05-05-2015 06:06 AM
heater core placement
Thanks for the pictures. Its amazing what you can get on ebay.
For some reason I was picturing the heat exchanger being mounted up front, but I see from the photos you put them in the back.
I ran my cooling lines through the heater duct work (rather than under the car), so that setup won't work for me. Im kinda hoping to use a universal air unit, mounted under the dash.
Somewhere on this forum there is a guy (from TX) that installed one, seemed like he had good success.
ChrisP911 05-09-2015 08:04 AM
yan2927 what does your A/C system look like.
Yan2947 05-09-2015 01:13 PM
Basically just normal with better hoses then original. I have two Spal fans on the rear condenser with room for a third but I don't seem to need it. Everything functions as new. The compressor is just GM.
Hope that helps. I used a local AC company that I knew very well.
ChrisP911 05-09-2015 01:20 PM
OK cool thanks
Yan2947 10-18-2015 07:12 AM
Spyker radiator design
I was at a Spyker car cruise yesterday. Thought of taking some photos of the Spyker radiator design and routing for all you front mounted radiator peeps...
http://forums.pelicanparts.com/uploa...1445177170.jpg
http://forums.pelicanparts.com/uploa...1445177469.jpg
Out the hood the hot air goes... I have seen a 911 somewhere on this site with such a hood. Looks fine on a Spyker. Not sure about a 911 but it must do the job.
Yan2947 02-02-2019 04:37 AM
For everyone looking for radiator options - I still have my 89 911 ls1 with a toy-jet rear radiator. It still works. I have never overheated. I have gone through the thoughts of the front valance radiator setup but when I was done it didn't seem like it was an easy option. I thought that having a simple additional radiator up front would be enough to cool the radiator on long highway rides. The end result was getting a tall 5th gear. I have taken the car to the 1/4 track and never had a problem even on upper 90 degree days. The high rpm on the long road would be the problem and getting the tallest 5th gear dropped the rpm's down to an area that I have never worried about. The LS motors run hot. I do not think there is much of a coolant temp difference between the front radiator options and the rear mounts. At least with the rear mounts you could all test out the theory on your own. Take off the lid and mount a horizontal radiator without much effort like I did and drive it. Mount a good spal fan and you could have your car running in no time. Get your numbers, change a gear or two - you need to do that regardless. Plan on a reallllllly tall first gear and your daily driver/occasional 1/4 car would be perfect. Not sure about a track but 1/4 no problem on hot days. If you drop the rpm you won't overheat. I have the toyjet wing after making my own and trying to retro fit radiators in different wings. The end result was that Clemon (Toyjet) created a decent looking wing after numerous changes. The early wings worked but perhaps didn't look as appealing. Not sure if he is still doing the toyjet wings but his website is still up. My cabin heat setup works perfect too. Its way too simple and cheap for you to try something else. It uses the existing heater ducts with a bullet intercooler on each duct. Simple and works great and works off the existing heating controls. I know renegade stuff works. They are awesome and I used them on everything except the rear radiator. They are a class act and I even visited them in Las Vegas. Class Act period. I just didn't want to cut up the front of my car. Just throwing this out there again.
Yan2947 02-24-2019 05:37 AM
Not sure what I am thinking knowing that I am done buying toys but I decided to tinker again even after having a perfectly running 89 911 ls1. I jumped into this 80 sc with slant nose conversion Stroker 383 with a purpose built CMS 915 Tranny 460HP/450Torque race car to turn it into a more street comfortable machine. Any thoughts? New thread?http://forums.pelicanparts.com/uploa...1551015231.jpg
Diggem 02-25-2019 09:20 AM
That will be a very nice street machine. I like it!!!
dtakenname 02-26-2019 05:03 PM
Hi,,
Nice looking car,
Are those steel flares?
What was done to the transmission?
What is the rpm at 60 miles/hr?
Any creature comforts in the car? heat....etc?
Yan2947 02-27-2019 02:47 AM
Steel flares and fenders. No creature comforts yet. It was a track car. The tranny 915 tranny was purpose built at California motor sports and I am waiting for the paperwork on it.
Diggem 02-27-2019 09:36 AM
Hey Yan, I would also like to know what was done to that 915 in order to live behind that small block chevy torque and horsepower.
Yan2947 02-27-2019 08:03 PM
915:
CMS Invoice
Date
3/29/2011
915 V8 mid engine
1 basic rebuild labor: includes teardown, inspection, cleaning, re-assembly
1 915/930 4 point main shaft bearing
1 915 pinion shaft 4 point thrust bearing
2 diff thrust bearing
1 915 1st gear synchro ring
1 915 2nd gear synchro ring 11
3 901 1st-5th & 915 3rd-5th synchro ring
1 30x1.5 Shoulder Nut (input shaft)
1 915 lock nut, pinion shaft
1 trans hardware
1 Shop Supplies 25
1 Sealant 5
1 915 gasket set
free gasket set promotion -
1 915/930 1st/2nd shift sleeve
1 915/930 3rd/4th shift sleeve 29
1 915 1st gear dog ring (asymmetrical)
1 915 3rd gear dog ring 19
1 repair bell housing bore
1 reverse light switch
1 915/930 Pinion Shaft Cyl. Roller Bearing in bell housing, rear
1 915 reverse "H" gear, good used
CMS Invoice
Date
3/29/2011
Optional upgrades:
1 OSG LSD
Diff setup labor (if LSD is added)
1 tall 4th gear 0.86
1 tall 5th gear 0.68
1 CMS billet bearing plate
1 CMS billet side plate
1 119 Setrab oil cooler, 6x19 row, with electric fan (cooler size 5 3/4 H x 8 1/4
W x 19 rows)
1 Peterson 600 series billet oil filter W ITHOUT TEMP PORT, 153.30 153.30T
1 CMS internal spray bar 495.00 495.00T
1 Tilton transmission oil pump 228.00 228.00T
2 AN adapter, 3/8, -8, male 0.00 0.00T
1 Cooler Fitting -8 0.00 0.00T
1 Cooler Fitting -6
1 915/930 pinion setup shim .15 9.16 9.16T
1 915/930 pinion setup shim .20 9.88 9.88T
Bigtoe32067 05-20-2019 01:02 PM
Please start a new thread for this car. I enjoyed your ls1 thread immensely and would love to follow this one as well
Tony
