-   Porsche Engine Conversion Tech Forum (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/)
-   -   89 911 LS1 Conversion (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/556905-89-911-ls1-conversion.html)
Yan2947 10-28-2010 04:48 PM
the mock up...
http://forums.pelicanparts.com/uploa...1288309624.jpg
http://forums.pelicanparts.com/uploa...1288309678.jpg
http://forums.pelicanparts.com/uploa...1288309710.jpg
Yan2947 11-03-2010 12:30 PM
Well, my wing came and the mock radiator fits with plenty of room to spare!
http://forums.pelicanparts.com/uploa...1288812485.jpg
dtakenname 11-03-2010 07:57 PM
Hi,
Great job!
Do you see any need to change any suspension parts? How is the car sitting? Does it sit lower or higher than before?
Keep going.
Yan2947 11-03-2010 08:14 PM
thanks! So far it looks like it is sitting a bit higher but I don't have the radiator in yet. It should be the same or pretty close to the original height. I just replaced the rear struts. My old ones were fine but it seemed like a good time to change them.
Yan2947 11-27-2010 12:45 PM
Exhaust is in. Probably going to put in a cross flow but going to wait until the motor is on to see how loud this setup is. I used Magnaflow mufflers.
http://forums.pelicanparts.com/uploa...1290890665.jpg
Yan2947 12-07-2010 02:50 PM
Well, here are some teaser photos. Radiator just came...
http://forums.pelicanparts.com/uploa...1291762049.jpg
http://forums.pelicanparts.com/uploa...1291762076.jpg
http://forums.pelicanparts.com/uploa...1291762101.jpg
http://forums.pelicanparts.com/uploa...1291762125.jpg
http://forums.pelicanparts.com/uploa...1291762154.jpg
http://forums.pelicanparts.com/uploa...1291762181.jpg
http://forums.pelicanparts.com/uploa...1291762211.jpg
Yan2947 12-07-2010 02:51 PM
And it weighs 25 lbs empty.
drmatera 12-07-2010 03:43 PM
very cool. I love the power delivery of the LS engines. And to think 600hp is only a cam and head swap away.
I like how your exhaust turned out. keep at it...!
Windsor4273 12-07-2010 05:50 PM
I sold my 2004 GTO with the LS1 to buy my 911. You are about to have the best of both worlds!
balleta 12-08-2010 12:12 PM
Very nice swap. Like the reverse option on it. But, that huge tail in a narrow body car doesn't seems like a good package. I think that after the power conversion you'll need some body changes to go with it.
Go on, good job!
Yan2947 12-08-2010 03:11 PM
balleta,
I couldn't agree with you more. I already took it off. Do you have any ideas to fit such a large radiator. I'm leaning towards the dp935 or do some thing custom - like a scoop on top of the radiator on the turbo lid - then there would be no wing. I will probably mount it on the lid just to get the thing stable and then get it running. After its keeping temp then find a wing...
Yan2947 12-21-2010 10:09 AM
Some changes...http://forums.pelicanparts.com/uploa...1292954808.jpg
http://forums.pelicanparts.com/uploa...1292954859.jpg
http://forums.pelicanparts.com/uploa...1292954890.jpg
http://forums.pelicanparts.com/uploa...1292954912.jpg
http://forums.pelicanparts.com/uploa...1292954938.jpg
This setup will allow me to get the car running. Still not sure about wings.
drmatera 12-21-2010 10:45 AM
I would consider closing off the hole in the engine lid where the fans are so all the hot radiator air would just blow out the back of the wing (DP wing with a "grill"). The uppermost hole in the lid could stay open for engine breathing..
Yan2947 12-21-2010 12:19 PM
The big hole is for my future condensor - possibly. Once the car is running I will see where the temps are. Need to get this thing started. I have my fingers crossed that the engine will be fine. I've read too many swaps where the engine bought was blown without the knowledge of the buyer.
drmatera 12-21-2010 01:09 PM
funny you mention that. I bought a 6.0L motor out of an 05 Escalade, I was so worried about it that I hooked fuel and a battery up to the engine/trans while it sat on the floor and fired it up. She ran fine but my neighbors thought I was insane
Yan2947 12-21-2010 03:14 PM
Better to be sure. I got my motor from: Welcome to Contemporary Corvette
They have been around for some time in PA and were recommended. I was really cautious to buy one from some unknown ebayer. Hopefully next week I will find out...
Yan2947 12-27-2010 06:11 AM
Hopefully, Mother Nature will let me get this 89 running today...
Yan2947 12-27-2010 06:16 AM
http://forums.pelicanparts.com/uploa...1293459385.jpg
lin7310948 12-27-2010 08:19 AM
yan, if you are resolute about the radiator being in the rear...over the motor...i would consider adding rear turbo flares so that a large tail would be appropriate. unless you relocate the radiator to the front, i dont see how you can accomplish a suitable balance for the rear wing. with turbo sized flares you could use the tail that you bought, or a teatray, or a dp tail.. hope you get it fired and going today. i am expecting delivery of my Mast Motorsports LS7 engine in about two weeks....
balleta 12-27-2010 08:40 AM
Agree with that idea, but just a temporary cover with before and after temp readings.
I will consider the condenser in other place, maybe in the front. Just to not get the rear too crowded. Plus it will add more weight to the rear lid.
Good luck!
Yan2947 12-27-2010 03:16 PM
Thanks for words. I would love the rear fender flares and perhaps they will happen one of these days. I'm not overly concerned with AC either but it would be nice. It may be more appropriate to have the condenser in the front to keep the rear less crowded as stated. On another note. We got off to a late start today because of the snow so tomorrow will be another day.
We ran into problems with the wiring harness being way too short. Is there any reason why one couldn't put the computer in the engine compartmentr... Seems to be weather proof and properly sealed? Please chime in on this one...
thanks!
shanghai_todd 12-27-2010 05:14 PM
Put my PCM in the back seat and made a rear seat delete panel which slides out. Not sure if your harness has an ODB++ port but if it does mount it somewhere you can access it easily. I put mine in the middle and connect my diagnostic tool to monitor temp, rpm, IAT, ect..
BTW, my PCM was ordered for a 99 5.7 LS1 Camaro, now that I got the 08 LS2 Vette motor I plan to have the car Dyno tuned early next year. Figure I can squeeze an easy 40hp and get a more optimal fuel curve. In the higher RPM range I feel I am losing torque and power which could be the tune or fuel pump. No telling for sure until she gets hooked up to the Dyno and air/fuel ratio is recorded.
http://forums.pelicanparts.com/uploa...1293498138.jpg
http://forums.pelicanparts.com/uploa...1293498212.jpg
Yan2947 12-27-2010 05:31 PM
Todd, that rear seat delete looks great and an amp under the front seat? Has anyone put one of these pcm's in the engine compartment?
Yan2947 12-29-2010 12:58 PM
http://forums.pelicanparts.com/uploa...1293656098.jpg
http://forums.pelicanparts.com/uploa...1293656144.jpg
Well, did not realize the Camaro Harness was so short. The only good place to mount the computer was in the motor compartment. Apparently it is a common place to mount for the GM cars. Its been a slower week then expected but a lot of stuff is getting done.
Yan2947 12-30-2010 02:59 PM
Well, she fired up today for the first time. Here is a link on youtube:
YouTube - 89 Porsche 911 LS1 Conversion
Still have a few things to do...
Yan2947 01-03-2011 03:42 PM
Took the car on the first ride. What power. It is almost unreal. Temp seem totally fine. I will add that the outdoor temp was probably 40 degrees. The fans kicked on at 196 and cooled right down. Temps never went over 200 even when stomping on it but it was limited. We shall see what the week brings.
shanghai_todd 01-03-2011 04:17 PM
glad to hear you got here running. Awesome job adding another V8 powered 911 to the streets..
lin7310948 01-03-2011 04:34 PM
nice job yan. i received my wiring harness today. the motor is almost built...awaiting oil pan and dyno...hoping for 700 plus chp!
Yan2947 01-03-2011 05:19 PM
Thanks guys. It does feel good. Got lots of cosmetic things to do but I'm on the way. I'm picking up a 930 wing on wed. I'm hoping I can adapt it with some mods. Just not wanting to widen my tubs yet. I'm still trying to keep to my original plan of not cutting the car in any way with the exception of the extra lid that I bought. Good luck Lin with the wiring harness. Mine was pretty short and the only logical place became the engine compartment. 700 Plus... Can't imagine after driving this freak today. 350 seems like a ton! Good luck!
Yan2947 01-05-2011 04:07 AM
Drove the car for about an hour last night after work. The power response is amazing. There is no lag. It is instant power. 1st gear seams like a waste but of course I will use it. I am going to order one of those G-Tech Pro RR devices that measure horsepower and 0 to 60, 0 to 100, 1/4 mile, anyone ever use one? Do you like it?
sirhiss 01-06-2011 04:03 AM
Hello
I have put my ecu to the left of the engine like the original Porsche. I made a alu plate to the fuses relays and ecu so i can take it out as one unit. Clean and easy.
http://forums.pelicanparts.com/uploa...1294315362.jpg
Regards from Denmark
Yan2947 01-06-2011 04:14 AM
sirhiss, that looks really clean! It looks great. I will post some newer photos today but you really cleaned things great! I left some of the original wiring harness from the porsche. My original porsche ecu was under the driver's seat. How is your car running? Mine seems to be without any problems so far. I just picked up a 930 wing yesterday and I have to see how to make my design work with the wing. Have you measured any times yet or hp?
thanks for the photo! Could you post some more of your build here also!
Yan2947 01-07-2011 11:49 AM
I've added some photos of the completed engine compartment. I will do some modifications to tidy this area up in the spring. Right now I'm finishing up the wing from a 930. Hopefully it won't look too cut up. I decided it is just the right size for my narrow body. The 935 DP wing is great but too big and my AIR wing is incredible but too big also. Anyone want the AIR wing I will sell it for $350 plus shipping. You can see it in some of the photos above or on page 5. My G-Tech device will be here next Thursday so I will be able to give some really quick and reliable perfomance numbers to lay out what this car does with a stock '02 LS1 from a Camero. According to Jim's Performance, who Rengade sent my ECU to, the hp increase by tuning and turning off some of the "California" stuff should add approx. 40 to 60 hp. Not sure how that is possible but I have driven the car and it is scary fast!
http://forums.pelicanparts.com/uploa...1294429699.jpg
http://forums.pelicanparts.com/uploa...1294429725.jpg
http://forums.pelicanparts.com/uploa...1294429746.jpg
neptunechris 01-07-2011 12:28 PM
I am supportive of anyone who engineers their own path with their own belongings. I have a hard time remembering...did Porsche build a car with a front engine, V8, water cooled? or maybe a six cylinder rear engine ....water cooled...I get so confused. There are many things that make the 911 and Porsche the best...engine is only part of it..but it seems even the German engineers like to be "flexible" in powerplant choices.
Fischer_76_911S 01-08-2011 11:02 AM
Looking great. Don't worry about the purists. Here is a picture of my LT-1 swap. Radiator in front. I'm only running 350-375 hp but I can hang the tail out at the press of the right foot. The power, as you now know, is really linear and the torque is unreal. I've taken other 911 owners for rides and they can't believe the power. You can drive it in town all day too, if desired. It is the best of both worlds. To all the purists: I also have a '99 996 convertible with a stock engine. I will say you haven't lived until you hear the mechanical bliss of a 911 at the last 2,000 rpm to redline. It is a GREAT car - no denying it. But my V8 will just run circles around it and any high school auto class kid can work on it. For performance, I'll take the V8 any day. For finesse, I'll take stock. There is room in this world for both. Don't be so judgmental. Enjoyed your thread, keep it up.http://forums.pelicanparts.com/uploa...1294513192.jpg
http://forums.pelicanparts.com/uploa...1294513252.jpg
sirhiss 01-11-2011 11:23 AM
Hello again
Here is a picture of the alu plate i used for all my ecu etc.
http://forums.pelicanparts.com/uploa...1294773558.jpg
And here is a link to a Danish web page (early911.dk)where you can see my projekt, it is from Denmark but you can see the pictures:) have a nice day
Early911.dk • Vis emne - En lidt anderledes renovering-ombygning af 911t årg.72
911JeffS 01-15-2011 01:51 PM
Hello Yan-
Nice thread, Your ride is Lookin good! Thanks for sharing a great build, I will post as I make some progress on my 1977 911S Targa LS1 project. I have been gathering/obtaining parts. With the the LS1 intake reversed, I have read some others had trouble with the RH kit & the throttle body hitting the rear shock tower/body cross member and having to modify the body, thankfully, you did not seem to have this problem, are you running the stock intake & TB ? Since you aren't to keen on cutting up the car, I thought you might have a solution, or a fix, ( if this is at all nessescary ) Thanks in advance, I live over in nearby Ct. Would be cool if I could take a peak.
Jeff
Yan2947 01-15-2011 04:21 PM
Jeff, Its not really the tb that hits the cross member, but its real close, it was the adapter. That TB adapter got in the way of the lip on the cross member. Its that 1/2 piece of lip above the cross member. I had to file down a section about 3" wide. I just had so much trouble with the silcone coupler from the TB to the adapter so the easy solution was to file that lip down slightly. It still passed my "no cutting of the car". I am in 12486 zip in case u want to see the monster. Can't wait to see your build.
Yan
CorsePerVita 01-15-2011 06:43 PM
Looks like a tight fit but what a cool project! Can't wait to see it 100% finished.
911JeffS 01-16-2011 01:03 PM
Yan-
Thanks for the response, I will PM you for contact info. Like yours & sirhiss my ECU will also be in the engine compartment. So is it the RH air inlet elbow the clearance problem ? Or will it be anything we attach aft of the TB ? I would like to find a solution, but I will modify the cross member if needed. By the way, a thanks to all the 911/LS1 guys on this forum who have inspired me & those after me.
Jeff
