-   Porsche Engine Conversion Tech Forum (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/)
-   -   89 911 LS1 Conversion (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/556905-89-911-ls1-conversion.html)
Yan2947 09-25-2011 11:28 AM
e p slick, that is a sweet V8. Nice work! How expensive were the gear changes? 200mph! wow!
e p slick 09-26-2011 06:31 AM
10 years ago
I built this car 10 years ago so memory is hazy. Paul Guard pieces + labor etc. was around 5K.
EPS
toyjet2000 09-29-2011 01:36 PM
Reare Radiator system
http://forums.pelicanparts.com/uploa...1317328148.jpg
Yan, this is the system I have been running for a while.
It also houses the AC condenser.
Yan2947 09-29-2011 04:18 PM
What are your normal and high operating temps of the engine on a 90 degree day. On normal days (70 degrees and humid) I stay at 200 degrees but on 85 plus days I have seen my temps go to 220 and start to creep up to 225. I also know (or think) that 225 is really not too bad for these engines that like to run hot but any hotter and one has to worry. I know my radiator from Ron Davis is large enough for about 416 hp even though I am only about 350 hp (untested). I have had the car up to some high speeds on the hot days and I stayed above or at 220 degrees. Could not drop down to 200 until I met the speed limit. I have decided to add a small radiator in a new fiberglass front spoiler (935 model) from better bodies motorsports. Once I mount the spoiler I going to mount a radiator there. I have thought of adding a subaru wrx hood scoop to the wing. The 4" tall scoop would direct much more air into the rear radiator. Perhaps I should do that before I add the front spoiler. What do u think? It certainly won't look too stock.
toyjet2000 09-29-2011 08:27 PM
It works well.
I have been beta testing one on my new designs on my car for about 3 months.
Results so far.
In 100 degree Texas humid weather it maintains about 160 degrees in stop and go traffic. It goes to 190-195 when maintaining 80 mph. on the hwy.
The temperature is controlled by an adjustable rheostat that gets it signal from a
thermostat bulb, which in turn pulls in, a relay to cycle the cooling fan on and off.
With the same summer temperature settings:
On cold days the engine temperature runs a little hotter because it takes longer to turn the fan on because the temperature bulb utilizes the radiant heat off of the radiator surface area to send a signal to a relay to turn the cooling fan on.
You will have to re-adjust the rheostat in the wintertime to set your temperature to the desired value you want to maintain. My rear cooling system has never over heated or went near or above 210 degrees under any circumstance.
And keep in mind I am running a supercharger and a motor with over 600 hp.
Yan2947 09-30-2011 05:53 AM
I have a themostat. What is the rheostat and how can that benefit me with this rear wing? My fans seem to go on quite a bit.
toyjet2000 09-30-2011 09:25 AM
Rheostat
I do not know if it will benefit you.
My rheostat acts like your thermostat except it manipulates my fan control not water flow.
It is an adjustable device that senses temperature then pulls in a relay when that desired temperature is reached. The relay is hooked to my fan. All in a nutshell it is acts as an electronic thermostat rather than mechanical.
shanghai_todd 10-01-2011 04:51 AM
Yan
What RPM are you at and what are you considering as high speeds? I have done both a rear radiator in my initial conversion and this year swapped to a RH front mount and in both systems have seen similar temps that you have mention but in Florida weather. My experience is that holding the RPM @ 3K for a cruising speed can drive my temperatures upward in the 215~220F range and if maintaining @ 2K RPM on the highway is 205~210F.
Other factors to consider
- AIR in the lines (Took me 1 day of burping my system to get all the air out)
- Spark plug gaps (This can cause a hotter spark)
- Air/Fuel ratio
- Exhaust element (muffles tucked close to motor, back pressure, heat shielding)
- Dyno tune
Yan2947 10-01-2011 06:25 AM
Todd,
If I were to maintain 3K RPM on 90 degree weather I would never go above 205 degrees. Anywhere above 4K is where it creeps up. At this point in the year even at 5K RPM I am not going to heat up above 200 or 205. I think my radiator is oversized well shielded and a good portion of the air being sucked through goes out the back of the lid before entering the engine. Plenty still get into the engine area but it does help to have the cut out at the back to allow plenty to fall out the back. I will have to take some fall cruises to see where I am now with temp/rpm and speed. The car has been quite a sunday driver so I need to see where the open road sends the temp gauge. I will try it again this week and post some better results. If anyone has an extra - not used - wrx scoop (4" tall) please chime in!
toyjet2000 10-01-2011 07:16 AM
Toyjet Cooling system
“Toyjet Cooling”
Lets keep in mind when others post about the pros and cons of the rear radiator system and their experiences, they are not referring to the Patented "Toyjet Cooling System".
They are referring to a system that they made themselves or purchased from some other entity other than Toyjet Conversions Inc.
My Toyjet cooling system operational cooling temps are much different and much more forgiving than what I am reading in this post.
I am challenged to get my LS1 to run the desired temperature the LS1 runs optimally at. I have absolutely no issues with my car overheating or ever getting near or past 220 degrees in any circumstance or weather condition.
When I first invented the Toyjet cooling system, I experienced exactly what you guys are going through. After extensive research and development I solved the over heating issue. I participate in as many local parades and car cruises as I can and occasionally drag race my vehicle with no cooling issues at all. The design of the system is the key.
Yan2947 10-01-2011 07:59 AM
Clemon,
I realize you have a lot of time and money invested in your design and appreciate all your help. I have no problem dragging my car in 1/4 runs and keeping the temp low and there is no way my car will ever overheat in a parade on 120 days in NY or Texas. The only issue I have seen is at long distance high speeds. A highway or track at 120 mph for 10 miles. The temp jumps up. With your DP 935 new tail that is not so different then my turbo tail with the cut out. I think it is very different then your patented tail. That tail is much higher then mine and allows much more heat to exit the rear. If your dp tail is doing the exact same thing as your patented tail then we have to be pretty close on temps unless....... you are also making all of your hot air from your radiator on the dp tail exit the rear without ever hitting the engine. That would be harder with the 930 tail. If you can see something that I am missing please feel free to call. I will PM my number to you.
Yan
Yan2947 10-01-2011 08:06 AM
Todd,
after your final conversion are you saying that your temp on the motor were about the same with your front compared to your rear radiator with the same weather conditions in FL?
toyjet2000 10-01-2011 12:42 PM
Toyjet Design
Yan,
You are correct.
I am venting to the outside. My air is exiting about 50% outside and 50% in the engine compartment. Since my wing is slightly longer than a stock Turbo tail, no air is hitting the engine. The 50% that's in the engine compartment is blowing in front of the motor, right over the deck-lid latch area and water pump adapter area. My wing is a custom made wing that is about the width of the stock AC condenser longer than a factory turbo tail. I purposely designed it that way so I do not have hot air blowing directly on top of the engine. This could be making a slight difference, that's my guess.
Yan2947 10-15-2011 12:32 PM
Check out Toy-Jets water pump adapter and motor mounts. I like the fact that he doesn't use an engine cradle. More room down there without the cradle. The water pump adapter gives a bit more room and is neater then using that extra hose. Single line in/out on his water pump. Nice and neat. RH is great but Toy-Jet is very inovative. I now understand why his rear wing/radiator works. I shall be upgrading my wing in the future to his new wing design....
http://forums.pelicanparts.com/uploa...1318707037.jpg
toyjet2000 10-16-2011 07:44 PM
Engine Mounts
Here are the engine mountshttp://forums.pelicanparts.com/uploa...1318819417.jpg
Yan2947 10-17-2011 10:47 AM
Clemons,
so you have no issue with the engine cradle since you don't use one. You have more room on the bottom. It took quite a bit of work to get the exhaust around the cradle. Nothing to crazy but you avoided that all together. It is great to have 2 schools of thought on this idea. People can make their own choices but this gives a great alternative at a respectible price! Nice to see the actual work!
thanks!
yan
sirhiss 10-18-2011 12:27 PM
Hello Yan
Now i have recived my "batwing" (Corvette) oilsump and my new hollow torsion bars 29mm is on the way from sway a way. What does mr. toy jet use for rear suspension?
Yan2947 10-18-2011 08:06 PM
Sirhiss, I am not sure that Clemons changed his torsion bars but he likes 1" taller tires. That may solve some issues with oil pan slamming/squatting!
mystro 10-19-2011 03:43 AM
X2......just cause you can, doesn't mean you should. :confused:
Originally Posted by cole930 (Post 5489199)
Don't mean to be negative but, I love these cars too much. To me it's like cutting the center out of a Picasso to insert an Al Capp cartoon.
I certainly respect your right to do what you want with your car but your either a Porsche guy or your not. Your not. I would respectfully encourage you to go buy a Corvette.
Cole
pcar9119 10-19-2011 05:11 AM
This is a good discussion on this mod. Don't ruin it by coming on this thread and *****ing. I'm trying to learn somethings on this topic. Don't start wailing about correctness and purity. There's a thread for that too... :)
drmatera 10-19-2011 09:27 AM
It's is funny how people would rather the car sit and rot in the junkyard because of a blown motor before getting an engine transplant... Not to mention a late model LS-x series engine has more technology, better power to CID ratio, better fuel economy, cleaner burning, cheaper to repair, cheaper to modify and a hell of a lot faster per dollar.. Seems to me putting an aluminum LS1 into these cars just improves it..
But i'm not purist
911JeffS 10-20-2011 06:13 PM
Yan-
Lookin good, keep it up, I think your teaching us the course.
Jeff
not_hans_stuck 10-21-2011 06:17 PM
Cole
So if I understand your analogy, replacing a 911 engine with an LS1 is like cutting the center out of a weird european thing that nobody understands and putting in a simple American classic.
I'd say I have to agree. ;)
H
stlrj 10-22-2011 01:06 PM
H
In all honesty, an LS1 really does belong in a 996, considering the nightmare issues some have had.
pcar9119 10-23-2011 04:13 PM
I talked to Clemon at Toyjet thursday. He had alot of enlightening things to say about his system and all his adaptation pieces. I will be definitley buying his stuff. His mounting system is so clean and leaves lots of room for headers. I want to build some 180 headers for my car and now will have room to do this with his mounting kit.
Yan2947 10-24-2011 03:33 PM
Pcar9119,
glad you found a way of solving your 180 headers. Can't wait till he finishes his heating system for my car! Its getting cold here in NY!
Just put in some rear speakers - Kenwood KFC-X463C. They were 4 by 6 rear deck speakers and fit nicely. I had to remove the Porsche speakers in the rear and re-use the metal bracket. I had to take out my dremmel tool and cut away part of the bracket. After that was done and the bracket fit nicely to the Kenwoods, I cut out, using the dremmel, the area that the grill attached to my old speaker. I cut that area out and then put it on top of my kenwoods. The original screws went right to the metal bracket and then the grill popped on perfectly! Took about 2 hours total. Even though the rear speakers are not the greatest for sound in a little porsche, it helps to cut out some of that rear 350 hp sound coming through. I also used the dremmel round file to smooth out the edges on the metal and the plastic!
Sounded perfect with my Alpine amp, Sony Head and JL Audio front speakers!
carsonmx114 10-25-2011 05:25 AM
I read through quickly (have to get to work), what's everyone doing for heat? I'm thinking that I'll build a heater box under the left rear seat and put an inline thermostat on the hot side of the system just after the input for the heater core. My car has a duct running down each side of the car. I assumed that one was fresh air into the stock heater manifolds and the other was hot air back into the car. Am I right?
Thanks.
hcoles 10-25-2011 07:40 AM
But i'm not purist
+1 - I see a quote around here something like "didn't see a sports car I liked so I built my own" putting a different engine in seems compatible with that statement, not sure of quote origin
Yan2947 10-25-2011 11:27 AM
I am waiting for Clemon's heater box around a muffler. His system connects to the stock 911 air ducts with a small fan on each. Hopefully he is working on it right now. There would be no need for anything else. Simple and follows the design of the 911 utilizing what the car already has.
masraum 10-25-2011 12:31 PM
Originally Posted by lindy 911 (Post 5488954)
Your 3.2 with some tweaking far less than that required for a V8 install will kick the ***** out of an LS-1 in a 911 chassis. Do what you want, but taking a perfectly good car with a rebuild-able motor and stuffing a V8 in it, will produce a TURD.
Just my .02
Lindy
?? Really? I'd love to know how "some tweaking" to a US spec '89 3.2L will kick the poo out of an LS1?
I LOVE Porsches. Love them, seriously, just think they are awesome cars. I miss my '88 targa every day.
But unless you're talking about adding a turbo or supercharger (which would probably require more than tweaking) or you're talking about a 911 race motor or unless you're talking about one of the late model GT3 engines, I'm not sure how you can honestly compare power output per cost or power output per weight of an LSx engine and a 911 engine.
carsonmx114 10-25-2011 12:31 PM
I see. I was hoping that my car had provisions to circulate the air through my heater box. I wonder what I'm missing as far as fans or control valves...I haven't seen any other plugs or wiring that I haven't accounted for unless it was in the engine wiring harness. I was under the illusion that when I set the dial to heat the air would circulate down one duct and back up the other.
lin7310948 10-25-2011 02:19 PM
i have a front mounted radiator suitably enclosed. my plan is to duct air directly off the radiator enclosure to the cab. i will take hot air via two 2.5 inch flexible tubing hoses directly to the cab. and if necessary will provide air to the defroster vents from those two sources. i might even get fancy and put a shutter in the duct tubing to control the amount of heated air coming into the cab. simple and no weight!
masraum 10-25-2011 04:10 PM
you're either a Porsche guy or your not. Your not. I would respectfully encourage you to go buy a Corvette.
Cole
:rolleyes: What a crock. That's just silly. Porsches and 911s are great. I love them. I can't wait to have another but I also think that there's nothing done with one of these conversions assuming it's done well. If the engineering is there so that the thing runs well and doesn't have reliability or driveability issues, then I think it's completely fitting.
I like blonds, brunetttes and redheads. You know what, I'd also be happy with a blond that died her hair red or a brunette that bleached her hair blond, or hell, a girl that dyed her hair blue, green or purple as long as it's well done.
Don Nguyen 10-30-2011 09:36 PM
Do you have any pictures of the exhaust system? I have an Ls1 in my M3, and I may consider putting one in my 911 as well :)
-Don
pcar9119 10-30-2011 10:03 PM
That quote cam from old man Porsche himself!
lin7310948 10-31-2011 05:22 AM
not directed to me, but these are the headers that i put on my LS7 conversion. fabricated by Stainless Headers.http://forums.pelicanparts.com/uploa...1320062627.jpg
Don Nguyen 10-31-2011 09:30 AM
I was just actually looking at your thread, lin. I was trying to see if there would be any already built headers out there that can be used in the LS swap versus having to have custom ones made. I've seen guys use the factory cast iron ones, but I wanted something more free flowing, like yours.
wjfk32 10-31-2011 10:11 AM
http://forums.pelicanparts.com/uploa...1320080801.jpg
I met a guy who put a Banks twin turbo V8 in a converted wide body 911.
The body was fiberglass/flmsy..The engine was a super tight fit and heavy..
The more questions I asked about the car, the more of a butcher operation he explained...
He did the work and saved alot of money....but it just looked all wrong.. :(
Walt
mkingham 11-01-2011 05:47 PM
Hi Don,
I bought a set of headers that fit around the RH brackets. They were made by JBA Performance Exhaust, part # 1850S-3
Here are two pics
http://forums.pelicanparts.com/uploa...1320194843.jpg
http://forums.pelicanparts.com/uploa...1320194857.jpg
woywitka 11-02-2011 01:05 AM
Quite a project. Congrats to you for taking it on.
I think to each thier own. We have a 66' 440 Charger and I just love the sound and the way that car makes power. That feeling of American muscle is something to be so desired.
I also love the Porsche flat 6, that sound, the way it builds power, how it makes torque, the smoothness at 7K RPMS. Flat 6 engines just feel different.
To some a Porsche is the whole package, to others it is just the look. Everyone has different tastes.
