-   Porsche Engine Conversion Tech Forum (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/)
-   -   993 Vr6 Turbo project (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/660380-993-vr6-turbo-project.html)
prodigyporsche 10-05-2012 08:16 AM
i am doing this swap also.... i did a pros and cons list with the motor and i cannot find anything about the vr6 i was upset about....vr6 is capable of building just as much power as a flat six or more... and do it way cheaper.... the vr6 loves rpm.. not to mention boost! the tuning world for the vw's is almost endless.. you can drive it everyday and not worry about the timing chain covers leaking all over hell! id also like to state a vr6 is in my eyes up to par with a flat 6 in the sound department. you could say the vr6 has a heavy block compared to the flat six... but you get to do away with the giant oil tank of a porsche along with all the coolers in the rear.. all the engine surround tin....its a horse a piece.. i personally would never spend the money on a flat 6 again...unless it was a 01+ 996 twin turbo swap but even then the vr6 builds just as much power...the haters will say "i dont get it" but when it comes down to it using this motor is just making a good car better for the person who really wants to drive the car...
black944 turbo 10-06-2012 04:15 PM
The only drawback, that I would see is the you are putting a lot more weight up high, vs down low
jadewombat 10-08-2012 05:41 AM
Yeah, although only half as much weight up high as a W12 (....in a VW fridolin).
Volksforum.com - Ruud's Fridolin Project
http://www.volksforum.com/albums/fil.../002_51975.JPG
Lapkritis 10-08-2012 06:58 AM
In for the first burnout... get this done already. ;-)
prodigyporsche 11-22-2012 05:46 PM
how does your front motor mount work? or is it not fab'd yet? any idea how much boost you will be running?
Motorsport-Tech 12-10-2012 02:35 PM
What do you mean? are you talking about the engine cradle itself?
prodigyporsche 02-18-2013 08:40 AM
the mount on the accessory side of the engine. im changing mine so i can fit a different exhaust. just curious as to what yours turned out like.
prodigyporsche 02-18-2013 08:41 AM
sorry for the late reply :)
Motorsport-Tech 02-25-2013 03:44 PM
What we've come up with for one spot on the coolant system to replace the t stat housing. This is going to upper radiator. uses a standard chevy thermostat
http://i50.photobucket.com/albums/f3...psc6b7e971.jpg
Finally got the radiator bracket set up. Just need to weld the one half to the frame rail and it will bolt in and out pretty easily.
http://i50.photobucket.com/albums/f3...pse4b66749.jpg
http://i50.photobucket.com/albums/f3...psb8b1fd87.jpg
Scrapping the bilsteins with limited adjustability and picked up some h&r's. This should do nicely to get it on the ground.
http://i50.photobucket.com/albums/f3...ps8dd4e6b4.jpg
Motorsport-Tech 02-25-2013 03:47 PM
Throttle body and ecu just got here. Now i need to order turbo and piping and get that routed up. Sending ecu off to C2 Motorsports
http://i50.photobucket.com/albums/f3...ps487311d0.jpg
Also got a few bits for interior as well as the rest of the seals i needed
http://i50.photobucket.com/albums/f3...psae0df1e8.jpg
Here's my concoction for the upper radiator hose. I just made a billet flange and ran a super tight 90 to avoid cutting into the rear suspension brace. I need to cut this down and clean it up once the lower hose is fitted as its kinda ugly haha http://i50.photobucket.com/albums/f3...psf3046da2.jpg
Here's the tstat setup. Need to add a bracket as well as a bung for coolant to the head and ecu temp sensor bung. http://i50.photobucket.com/albums/f3...ps853db33a.jpg
Hoping for nice weather this wknd to paint bumper,wing and deck lid.
http://i50.photobucket.com/albums/f3...ps9c0096cc.jpg
I need to get a hold of a 90 degree elbow and hope i can trim it back enough to clear this. Much closer than i thought it was going to be. http://i50.photobucket.com/albums/f3...ps68099e9f.jpg
http://i50.photobucket.com/albums/f3...ps1ac0ae52.jpg
Motorsport-Tech 02-25-2013 03:51 PM
Started cleaning up the TB. Was thinking of polishing it, but that's just not my style on engine bay stuff.
http://i50.photobucket.com/albums/f3...ps88aca8ea.jpg
Motorsport-Tech 02-25-2013 03:52 PM
I'll grab a pic. I cut my bracket down and only use the alternator part and used the other mounting holes for the cradle
Motorsport-Tech 02-27-2013 02:10 PM
its a success! haha damn this was not where i applied the measure twice, cut once method. I had the lower and upper mixed up so i had to cut them off and duplicate the angles of each other. Anyway its all done now and the hoses have nice easy bends through out the car. Mount the fan and 2 bungs left to put in the crack pipe and cooling is finally complete.
http://i50.photobucket.com/albums/f3...pse9699cee.jpg
prodigyporsche 02-28-2013 11:03 AM
it looks really good so far!!
Motorsport-Tech 03-11-2013 05:25 AM
excited to finally see wires in the car :D
http://i50.photobucket.com/albums/f3...ps99eba27b.jpg
http://i50.photobucket.com/albums/f3...ps0d2e7aee.jpg
http://i50.photobucket.com/albums/f3...ps12af7f84.jpg
Motorsport-Tech 03-11-2013 09:40 PM
Started making the rest of the fuel lines. Damn i have a lot of small holes in my fingers :D
http://i50.photobucket.com/albums/f3...ps7751c935.jpg
http://i50.photobucket.com/albums/f3...ps9c924e55.jpg
No matter what length i cut the hose i couldn't get the factory fuel line not to have a drastic bend in it with my mix n match fittings so i ordered the correct fittings to shorten that up.
http://i50.photobucket.com/albums/f3...ps155265cd.jpg
After fittings get here the fuel lines and fpr are mounted and complete so im starting on a coil pack bracket.
10.32@154mph 03-16-2013 05:30 PM
great idea, I've thought about doing this conversion but thought I'd be crazy. Its looking good and def a lot cheaper to make 500whp with just a head spacer ;)
Lapkritis 03-16-2013 09:34 PM
Re: 993 Vr6 Turbo project
...and they make a heck of a noise while doing so. A replacement engine costs as head studs for a 911.
Motorsport-Tech 05-24-2013 02:20 PM
heres some things ive been finishing.
throttle cable. i had pegasus racing send me a sheath plus 4ft from the oem cable and then 144" of cable so i could run the cable just like factory thru the floor tube. since nobody makes a metric end we took a bolt, drilled it, crimped it and then welded the tip. fit right onto the porsche ball socket. for the rear my buddy stanley made an exact piece as the vw. this time he pulled the wire thru, melted the wire into the end and put some filler rod in there.
http://i50.photobucket.com/albums/f3...ps5db28b95.jpg
http://i50.photobucket.com/albums/f3...ps995c8045.jpg
and i needed to add a tab
http://i50.photobucket.com/albums/f3...ps9d6490bf.jpg
had to make this up to clear the wastegate.
http://i50.photobucket.com/albums/f3...ps14aca617.jpg
decided to go ahead now and change the cooling sytem to all AN fittings
http://i50.photobucket.com/albums/f3...psbe5d4dd5.jpg
all the wiring is into the bay. ready to be plugged in. i also shaved the alternator down a fuzz as it wasnt quite hitting the intake but now its got an 1/8th.
http://i50.photobucket.com/albums/f3...psd92d35f5.jpg
These allow me to keep the factory fuel lines and get a leak free fit. other end is AN.
http://i50.photobucket.com/albums/f3...ps0680f4b8.jpg
Motorsport-Tech 05-24-2013 02:23 PM
The pan clearance
http://i50.photobucket.com/albums/f3...ps4fa5345e.jpg
Motorsport-Tech 05-24-2013 02:29 PM
decklid clearance. they do make a plastic valve cover without that baffle that would probably clear the regular decklid. this motor sits surprisingly low in there.
http://i50.photobucket.com/albums/f3...ps7b5be092.jpg
Motorsport-Tech 05-24-2013 02:31 PM
how it sits now. its now just a matter of putting everything back together
http://i50.photobucket.com/albums/f3...ps66c0f8f5.jpg
onefstm 05-25-2013 01:40 PM
Looks great. I absolutely love the wheels! What did you have to do to make them work?
Also, is there an intercooler in the decklid?
pksystems 06-03-2013 09:42 AM
subbed
Motorsport-Tech 06-03-2013 01:11 PM
Hey buddy! The wheels were a nightmare and my lack of Porsche experience probably didn't help any. The wheels have an extra thick back pad. When i went to test fit i realized the stock studs were to short. Now if it wasn't bad enough needing to buy 60mm studs i then find out that when the rear hub is taking apart i will need new bearings. Now at the point i'm at they have flat back and could use to come out maybe another 1". I can't run a conventional spacer as the studs will stick out and hit the wheel. I could switch to a bolt on spacer but it would need to be thick enough to cover the extra long stud (to far out) OR cut down the 60mm studs which im not wanting to do. Ideally they would work best with stock studs, a 25mm bolt on spacer and they would be flush. I will most likely sell them.
No intercooler. I need to switch to the plastic 24v valve cover to remove that baffle and i could maybe get it to fit. i need to run my filter as well and that might need to go up in there as its already going to be close to down pipe. i will probably go water/meth injection when i'm ready to turn up the boost.
IllustriousIron 06-08-2013 04:20 AM
Really clean little project. I love the camo.
Motorsport-Tech 06-08-2013 06:46 PM
Finally got the 10 little trim screws i needed to install the rear glass. I used the rope trick. Super easy to do. Gonna try windshield tomorrow.
http://i50.photobucket.com/albums/f3...psaa31db02.jpg
Still on that wiring game.
http://i50.photobucket.com/albums/f3...ps608bfd9c.jpg
Motorsport-Tech 06-25-2013 02:18 PM
Had my buddy Stanley weld up some tips, dual 2.5" pipe and made me a smooth 2 into 1 transition. just need to cut a couple more tight 90's and exhaust is done. I'll get some oil and gas in it this weekend and see what happens.
http://i50.photobucket.com/albums/f3...psaef53383.jpg
58'' from turbo to tip. should be rowdy
http://i50.photobucket.com/albums/f3...ps0bfaa80b.jpg
Motorsport-Tech 07-19-2013 11:44 AM
lots of little things to button up but shes on the ground. went to fire it up and the fuel pump was locked up. looked a bit crusty but i thought it would work. nope. new pump on the way
http://i50.photobucket.com/albums/f3...ps594ac785.jpg
Motorsport-Tech 07-19-2013 11:48 AM
Some of the interior has arrived. need to send off seats soon.
http://i50.photobucket.com/albums/f3...psa695ecdd.jpg
Motorsport-Tech 07-19-2013 11:51 AM
exhaust complete
http://i50.photobucket.com/albums/f3...ps964a3694.jpg
Motorsport-Tech 07-19-2013 11:52 AM
Worked on the bumper while waiting for fuel pump.
cut some plastic templates
http://i50.photobucket.com/albums/f3...ps9f53bc0a.jpg
epoxied in
http://i50.photobucket.com/albums/f3...ps707703f2.jpg
sanded flush
http://i50.photobucket.com/albums/f3...ps0c6ca39e.jpg
first coat of filler
http://i50.photobucket.com/albums/f3...ps5bbee19f.jpg
Motorsport-Tech 11-23-2013 05:46 AM
exhaust finished. car is running and driving.
http://i50.photobucket.com/albums/f3...psfbf7bebf.jpg
http://i50.photobucket.com/albums/f3...ps13fef37a.jpg
jadewombat 11-26-2013 06:40 AM
Purty. Need some videos...:)
