993 Vr6 Turbo project
Ok a brief history. I would find myself day dreaming of cramming a vr6 into an air cooled beetle for the past few years but never really pursued it with other cars eating up my time and money. After researching a bit i realized that they make a adapter plate to run vr's in dune buggies using a few different porsche trans. so obvious choice right? Vr6 Turbo in a 911.
I started searching and found a 73 911 with a 930 conversion widebody. The guy was less than upfront about rust issues until after the deal was done. I wasn't happy and we needed to make this right. He says he also has a 91 964. no engine or trans, and just importantly no rust that would be perfect for this conversion. This chassis houses the beefy G50 trans that would be great for a Vr6t. We strike a deal and the car is on the way from florida. This was a cabriolet with fiberglass top. I never really knew what was "off" about it but after seeing a factory hardtop with the rain gutters i couldn't move forward with it. Plans now were to find a wrecked car and see if we can make a deal for the complete roof and graft it on. Just by chance, within literally days a wrecked 993 pops up and within a couple hundred miles to boot. After talking with the guy it started to make more sense to maybe just fix it. Luck would have it that the 964 part numbers are the same as the 993 for the frame rail and lower structure and i already had a car at home with a good front clip. Cut up a cabriolet to save a coupe? i had no issues with it. After striking a deal with Jeremy for the chassis we were on our way with truck and trailer to pick it up. So thats where we are at. I have acquired a crap ton of parts and will post more pics in a bit. Thanks to those involved in making this happen especially my boss Jr at Adaptec Speedware. Its nice to see companies get involved because of their passion for cars. This will be in the Adaptec/ Eurotrash booth this year. also big thanks to C2 Motorsports, Panzer Auto, Adams Rotors, Ramsperger designs, Stuttgart motors for all my porsche parts at cost and any and all my friends who stop by and help turn a wrench or just shoot ideas back and forth until we get one that works haha. The goal is to make Southern Worthersee may 18th. |
The damage. Now since im putting the radiator up front with a fan below it i needed to remove the trunk floor anyway which makes this much easier
http://i50.photobucket.com/albums/f3...d/IMG_6957.jpg Getting 964 ready for surgery http://i50.photobucket.com/albums/f313/volks888/006.jpg Then to recoup my cash back, sold all the panels http://i50.photobucket.com/albums/f3...d/7e03d13e.jpg |
Nice. Should make a good hillclimb or track car.
Keep this pictures and progress coming!
ok finally got the 964 parts out of the way (Thanks Weston) and reclaimed some of the garage.
i was going to finish up suspension and brakes this week but found a trade for the MO30 springs for some H&R's so that will hold that up until those get here Plans for the Vr6. Install a LC headgasket and ARP hardware. that will be enough to hold 400whp. I will be running a C2 Motorsports tune. should be good for 400whp. Will post some pics of recent progress later |
heres a few parts that i've collected. Griffin radiator, high volume water pump, flex a lite fan, 21 circuit painless harness, adapter plate and hardware for Vr to G50, gates 28ft high temp hose
http://i50.photobucket.com/albums/f3...d/9e4052ba.jpg http://i50.photobucket.com/albums/f3...d/7d6aa8bf.jpg http://i50.photobucket.com/albums/f3...d/80ede8f8.jpg http://i50.photobucket.com/albums/f3...d/ff7e6bd1.jpg |
Trans showed up after a long delay. also shorted me a starter.http://i50.photobucket.com/albums/f3...8/a837cb62.jpg
Then i just picked this up for a pretty awesome deal. http://i50.photobucket.com/albums/f3...8/66d2c635.jpg http://i50.photobucket.com/albums/f3...8/e168ff63.jpg |
I was mulling over a VR6 conversion myself. I have yet to get measurements from a VR6 engine but will it fit without cutting up the rear cross member? I was thinking about contacting Kennedy to see if they would custom make me a adapter to slant the engine some and then use a dry sump setup utilizing the factory 964 oil tank. I think a dry sump would be needed either way but maybe not? Looking forward to seeing how the engine fits. I am in the middle of doing a 1973 RSR body conversion on my 964 now and with no funds for an engine, the VR6 with some boost may be my best options for some good power.
Mike |
yeah my adapter plate is 15 degrees. no cutting is needed as this is 6" shorter than the ls block that guys squeeze in. im not planning on a dry sump just yet but we'll see after i lower the car how it all sits.
my buddy repaired the cracks in the rear bumper and got it into primer
http://i50.photobucket.com/albums/f3...8/7994b8cc.jpg http://i50.photobucket.com/albums/f3...8/1138a785.jpg http://i50.photobucket.com/albums/f3...8/afe0f9bc.jpg |
started rebuilding the calipers
http://i50.photobucket.com/albums/f3...8/18ca396f.jpg |
More body work. the rear quarter lost all its clear coat when i removed the factory rock guards.
http://i50.photobucket.com/albums/f3...8/fda72133.jpg http://i50.photobucket.com/albums/f3...8/c98fc96b.jpg http://i50.photobucket.com/albums/f3...8/9b93e506.jpg |
Looks really good! How does the front damage look with the fenders removed?
@Jeremy. The front looks a lot better without all the jagged edges :)
front bumper and fenders showed up finally. i got sick of searching for oem fenders so i just bought fiberglass to not hold us up any longer and since its getting vinyl wrapped this year i figured it'd be fine. http://i50.photobucket.com/albums/f3...8/930203bc.jpg |
Looking great! Will you do any type of heat or AC? If not, you should be approx. 2400lbs IMO maybe less :)
Looking good !!! I've been following it a bit on Facebook.
interesting build - cant wait to see more. VR6 is a fun engine
Progress from the weekend. the car is about rolling. will finish my centers this week and bolts should be here any day so i can get the wheels together. brakes are finished up, suspension is finished, steering linkage hooked up. getting trans in car this week and will get the clutch and shift linkage all lined out and then start the engine cradle.
http://i50.photobucket.com/albums/f3...8/a5919c26.jpg |
I'm ready to see the engine in place. =)
So? Could I get a link to the FB page?
Thank You!
vr6 mated to the G50
http://i50.photobucket.com/albums/f3...8/5eca88a2.jpg test fit. needs some modifications to the tstat housing but there is plenty of room elsewhere. http://i50.photobucket.com/albums/f3...8/683f5bab.jpg |
Gauge panel almost done. just need to mount some flush tabs on back and wrap in it black leather to match dash. boost gauge will be going in center console
http://i50.photobucket.com/albums/f3...8/d62b2e27.jpg |
WOW, it sits nice and low back there. I was thinking for sure there would be clearance issues on the rear top of the valve cover. Looking forward to starting my VR6 project when i find the funds.
That is definitely sitting lower than normal in this pic but its really a nice fit height wise. i'll post some pics this week with it in place and the deck lid on.
Are you planning on some crazy HP numbers or just something mild? If I go with a VR6 I think it is mandatory that I do something wild as far as HP. I think 600HP would possibly help the Porsche purest to overlook the fact that my car is no longer air cooled Porsche powered. hahaha
Are you doing a complete engine build for a turbo or just going to use the head spacer? From the looks of all the room back there, are you going to mount the radiator in the back with electric fans? I think a side mounted radiator with some ducting would be cool. That would allow for a single or dual top mount intercoolers. |
Radiator up front like the ls swap cars. bought a turbo bumper for the opening and have a electric fan on back of rad. yes im doing a turbo. headgasket on this 12v for now but i might build a 3.2 vr this winter. 500whp range. intercooler up in the wing or possibly smaller duals down below. after i get the cradle built i'll see what i have room for. what chassis are you planning?
I may try to mount the radiators in the front fenders like the 964 oil cooler and AC conditioner. I am working on a 92 964 chassis but I am back dating it to look like a 73 RSR with 3 piece 17" fuchs and steel 930 flares. I am also planning to modify original steel 1973 rear bumpers to fit the 930 flares so I have a lot on my plate before i start on the power end of this project.
here it is fitted in the correct location. plenty of oil pan clearance seeing as it sits above the sway bar. pretty happy about that.
http://i50.photobucket.com/albums/f3...8/9ffab653.jpg tucked in there. http://i50.photobucket.com/albums/f3...8/89cb0aa7.jpg |
Still looks like it may be possible to use a small duck tail style deck lid?
That would clear a duck.
Looking good!
some stuff going on lately. extended studs installed so i had to replace the rear wheel bearings in doing so. centers are stripped and and powdercoater. completed the underbody coating. more turbo parts have shown up as well as my inline tstat since i deleted the plastic tstat housing.
http://i50.photobucket.com/albums/f3...8/1af6cf25.jpg http://i50.photobucket.com/albums/f3...8/e6fdd73f.jpg http://i50.photobucket.com/albums/f3...8/ec34bfe1.jpg http://i50.photobucket.com/albums/f3...8/9fc5885c.jpg http://i50.photobucket.com/albums/f3...8/4b4aa25d.jpg http://i50.photobucket.com/albums/f3...8/8d566959.jpg http://i50.photobucket.com/albums/f3...8/f71b929b.jpg |
Cool project, although I don't quite understand the point. None the less very cool.
holy crap that engine is tall! gives you plenty of space either side of it, i suppose.
Really looking forward to seeing this thing on the road. I loved my turbo VR6.
