Will the 944 trailing arms fit on the 914 tranny? I know they fit on the stock VW IRS tranny, but how about another porsche?
Thanks, Cale |
I don´t know if the 901 fits in 944 trailing arms,
But I know that 901 fits in VW bug, and vw bug trans fits in 914 and 911 trailing arms. Then if the 944 trailing arms fits in vw trans, also fits in 901 trans. What do you want do ? I´m wondering Good luck
1972 914 914-6 gt look chevy 2.8 v6 (928 engine project) 1974 914 916 Look (3.2 webers engine project ) 1984 944 Auto 550 Spyder (replica) 914 side trans 2.2 type 1 1957 R50 1981 R100RS 2000 K1200RS My Page |
assuming this is going into a beetle:
yes the 914 (901) will work together with the 944 trailing arms, its just a matter of driveshaft length. however the 914 tranny is not the best choice to use in a beetle, I considered this for my project since I had one already, but the amount of fabrication needed to make it work would be prohibitive. best bet would be an early 911 (901) or a later 915, making this work on a beetle is much more strait forward. |
man, this post was old
I posted this something like 3 months ago, and since then, I've found out all I need to know, gotten all the parts, converted the 914 to a 911 nosecone and shift rod, and flipped the ring, also got 944 trailing arms and all 4 rotors/calipers (from a 88 Turbo S) ![]() :P nice big 4 pot brembos with 12" slotted rotors!!!! All I have to do now to get it all installed is finish a little work on my trans am and then weld in the IRS brackets....I have to finish a little work on my new 78 T/A before I get back to the bug.Thanks, Cale |
Cale, I know this is an old thread, but my brother just picked up a set of 944 brakes and is going to install them and a 901/915 in his Beetle. Do you have some links for project information that would be helpful. We have the Kieth Seume book but are looking for more. Thanks, Michael
No poblem michael, check out the performance ghia @ www.hsl.co.uk/PerformanceGhia/index.html there is lots of great tech info on there!
Cale |
Thanks for the link, Cale. It should help alot. Michael
