'68 VW Turbo Crewcab
Test fit. '79 3.3 turbo motor. http://forums.pelicanparts.com/uploa...1431992239.jpg
Purty
Test fit 2. I decided to go with a custom Bell intercooler for better air flow. Motor is a modified 3.3 930. Stock 3.3 bottom end, SC cams, ported 3.0 heads, xdi ignition, B&B headers, zork tube, 915 5 speed trans.
http://forums.pelicanparts.com/uploa...1433460130.jpg |
Test fit 3, things are getting tight. The i/c lines will clear, but need to make a new fuel line. The turbo should be back by weeks end, then will start on twin dump pipes.
http://forums.pelicanparts.com/uploa...1434341429.jpg |
Going to stick with the CIS from what I can tell there, but crank trigger with ???
Eletromotive xdi
Finally bolted in. Will spend the next few days hooking everything up, and finishing the exhaust.
The motor is bolted to a '84 915 trans rebuilt by Wevo. Stock 8:31 r&p, stock 1-4 with a early 5th gear. Also installed the Wevo bearing retainer plate and side cover.http://forums.pelicanparts.com/uploa...1435894802.jpg http://forums.pelicanparts.com/uploa...1435894824.jpg |
Nice build, I also suggest you to install a WEVO side plate as well...
JIM |
915 trans by Wevo. Complete rebuild, 8:31 r&p, stock 1-4 & early 5th. Wevo bearing retainer & side cover.
http://forums.pelicanparts.com/uploa...1436048228.jpg |
Finally up and running.http://forums.pelicanparts.com/uploa...1436586645.jpg
Very jealous...:rolleyes::cool:
A link to the turbo install write up.
VW Type 2 Bus: 930 3.3 Turbo Engine Swap |
All buttoned up. Decided to drop the motor after this photo and a few miles of test drives. Not enough air going through the i/c in the bulkhead, switching to a 964 i/c mounted in the stock location. Will also be making (when I can find the parts) 9.5" x 17" 3 pc fuchs for the rear, with either 245's or 255's.
http://forums.pelicanparts.com/uploa...1442274151.jpg |
Final version and on the road. Added some fat rims, 3 pc Fuchs 8x16 w/225/50/16 fronts, 9x17 w/245/45/17 rears. Swapped out the Bell i/c in the firewall for a 964 i/c in the stock location.
http://forums.pelicanparts.com/uploa...1445710548.jpg |
Sweet!! Did you make the cookie cutter exhaust? If not where'd you get it? I need two.
I made them.
Finally on the road.
http://forums.pelicanparts.com/uploa...1446599649.jpg |
cool
Amazing! Well done! How do you draw cod air into intake and ic?
3 scoops under the chassis w/3" dia. hoses bringing air into the engine bay. 2 hoses come up in front of 3-10" fans. The 3rd hose goes to the top of the i/c. 1 fan comes on with the ignition, the other 2 fans come on when the engine temp hits 180 through a thermostat switch. The louvered engine lid also helps.
| All times are GMT -8. The time now is 09:10 AM. |
