Go Back   Pelican Parts Forums > Porsche Forums > Porsche Engine Conversion Tech Forum
gumba's Avatar
'68 VW Turbo Crewcab
Test fit. '79 3.3 turbo motor.
Harold
'79 930/DP935 (sold)
'68 VW 3.3 Turbo Crewcab
Old 05-18-2015, 04:37 PM
jadewombat's Avatar
Purty
'66 11-window VW Bus (Fuel-injecter'd Super-1600, IRS, disk brakes, MB CLK rims)
Old 06-04-2015, 03:24 PM
gumba's Avatar
Test fit 2. I decided to go with a custom Bell intercooler for better air flow. Motor is a modified 3.3 930. Stock 3.3 bottom end, SC cams, ported 3.0 heads, xdi ignition, B&B headers, zork tube, 915 5 speed trans.
Harold
Old 06-04-2015, 04:23 PM
gumba's Avatar
Test fit 3, things are getting tight. The i/c lines will clear, but need to make a new fuel line. The turbo should be back by weeks end, then will start on twin dump pipes.
Harold
Old 06-14-2015, 09:11 PM
jadewombat's Avatar
Going to stick with the CIS from what I can tell there, but crank trigger with ???
Old 06-20-2015, 06:05 PM
gumba's Avatar
Eletromotive xdi
Harold
Old 06-20-2015, 07:11 PM
gumba's Avatar
Finally bolted in. Will spend the next few days hooking everything up, and finishing the exhaust.
The motor is bolted to a '84 915 trans rebuilt by Wevo. Stock 8:31 r&p, stock 1-4 with a early 5th gear. Also installed the Wevo bearing retainer plate and side cover.
Harold
Old 07-02-2015, 08:40 PM
Nice build, I also suggest you to install a WEVO side plate as well...
JIM
Old 07-04-2015, 12:55 PM
gumba's Avatar
915 trans by Wevo. Complete rebuild, 8:31 r&p, stock 1-4 & early 5th. Wevo bearing retainer & side cover.
Harold
Old 07-04-2015, 03:19 PM
gumba's Avatar
Finally up and running.
Harold
Old 07-10-2015, 08:51 PM
jadewombat's Avatar
Very jealous...
Old 07-13-2015, 07:56 AM
gumba's Avatar
A link to the turbo install write up.
VW Type 2 Bus: 930 3.3 Turbo Engine Swap
Harold
Old 08-06-2015, 07:25 PM
gumba's Avatar
All buttoned up. Decided to drop the motor after this photo and a few miles of test drives. Not enough air going through the i/c in the bulkhead, switching to a 964 i/c mounted in the stock location. Will also be making (when I can find the parts) 9.5" x 17" 3 pc fuchs for the rear, with either 245's or 255's.
Harold
Old 09-14-2015, 04:48 PM
gumba's Avatar
Final version and on the road. Added some fat rims, 3 pc Fuchs 8x16 w/225/50/16 fronts, 9x17 w/245/45/17 rears. Swapped out the Bell i/c in the firewall for a 964 i/c in the stock location.
Harold
Old 10-24-2015, 11:17 AM
Brando
quattrorunner's Avatar
Sweet!! Did you make the cookie cutter exhaust? If not where'd you get it? I need two.
Turbo powa!
1977 911s. it's cool
Old 10-25-2015, 11:16 PM
gumba's Avatar
I made them.
Harold
Old 10-26-2015, 05:55 AM
gumba's Avatar
Finally on the road.
Harold
Old 11-03-2015, 05:14 PM
Brando
cool
Turbo powa!
Old 11-04-2015, 09:40 AM
pkp4911's Avatar
Amazing! Well done! How do you draw cod air into intake and ic?
Old 12-30-2015, 08:50 PM
gumba's Avatar
3 scoops under the chassis w/3" dia. hoses bringing air into the engine bay. 2 hoses come up in front of 3-10" fans. The 3rd hose goes to the top of the i/c. 1 fan comes on with the ignition, the other 2 fans come on when the engine temp hits 180 through a thermostat switch. The louvered engine lid also helps.
Harold
Old 12-30-2015, 11:01 PM
