Go Back   Pelican Parts Forums > Porsche Forums > Porsche Engine Conversion Tech Forum
s engine in 1999 boxster
greetings
I want to let boxster owners know it can be done by the right people cheaply and reliably.
99 boxster, ims failure at 129k posted requests to install a 2002s engine into the 99 chassis. and lee and his father Marcello at hybrid motors in Fairview nj did the job.
Ecu 996. 3.4 mechanical throttle
Drilled and tapped cylinder heads for a 3.4 manifold.
2.5 wire harness modified, Added white wire to ECU connector to activate manifold switch over valve.
Used early 996 throttle and crossover pipe to 3.5 inches, 90° silicone elbow to 3.5 mass airflow housing. Insert 996 Mass air flow sensor into the housing
Cayman S airbox, trim engine bay one quarter inch by cylinders 123
Use 2.5 L fuel rail, Cayman S engine cover, adjust fuel trims. Engine not lowered.
The car easily goes in 4th where 3rd was the rule. probably 280-90hp. 24-6mpg after 2k miles. Total expenses: $4000 for a used 3.2 engine, $600 for the parts listed, and $3500 for labor.
Old 10-18-2015, 04:58 AM
jadewombat's Avatar
Pictures? Interested in seeing this.
'66 11-window VW Bus (Fuel-injecter'd Super-1600, IRS, disk brakes, MB CLK rims)
Old 11-06-2015, 06:18 AM
Tags
boxster , boxster s , conversion
