Go Back   Pelican Parts Forums > Porsche Forums > Porsche Engine Conversion Tech Forum
Information Wanted: LSx 911 - Engine/ Trans Mount Solid/Poly/Stock?
Looking for some feedback from those of you with V8 911 cars in use- What type of engine mounts are you having sucess with?
Will new stock spec mounts hold up or are POLY/Solids a must?
Anyone tried several and have an opinion about vibration etc..
Please share you experience
Greatly appreciated!
Keith
Old 04-21-2016, 10:07 AM
JJK78-951's Avatar
I'm running Hinson racing polyurethane mounts. Work well, couldn't tell you about vibration as the motor has a big cam but I think they do well and don't notice much vibration.
John~
2003 996 Turbo... 128K Daily-ish
2000 Accord V6... 275K - 65K motor/trans now given new life!
Old 04-21-2016, 11:37 AM
911 application? Or 944? I am asking about 911. Does Hinson make 911 mounts?
Old 04-24-2016, 06:55 AM
JJK78-951's Avatar
It is actually in a Boxster S. The mounts are more or less universal that I bought, just size difference I believe. WEVO has custom transmission mounts for the application, they may have motor mounts too.
John~
Old 04-25-2016, 06:35 AM
Swapper and Ruiner
not_hans_stuck's Avatar
Tarrett Engineering Semi-solids...
http://forums.pelicanparts.com/paint-bodywork-discussion-forum/502929-diy-iroc-rsr-conversion.html
http://forums.pelicanparts.com/porsche-911-technical-forum/649179-rsr-ls-conversion.html
Old 05-01-2016, 05:12 PM
