-   Porsche Engine Conversion Tech Forum (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/)
-   -   180 Degree Headers (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/902702-180-degree-headers.html)
utbeamer 02-16-2016 10:36 AM
180 Degree Headers
Does anyone have experience with building/purchasing 180 degree headers for a V8 in a 911? Or, have you tried a different method of getting rid of the lumpy V8 sound like a flat cam or exhaust? I would love to hear what you have done to smooth out the V8. I'm looking into an LS1 swap, but want to figure out this piece first.
lin7310948 02-17-2016 08:09 AM
might check with renegade hybrids. they built a set for someones conversion. they probably have a sound bite or pics available. lots of tubing seemingly everywhere below the engine!
utbeamer 03-03-2016 11:05 PM
Yep, they will be happy to build a set for $8k :eek:
70nyG 03-10-2016 09:20 AM
Make em your self. .weak fitting and wielding skills no problem, get an disused motor block with heads attached set up on motor stand , pvc pipe the same size as your headers going 2b ,heat gun ,protractor ect,ect, and mock them up..by far the most expensive part is the fitting. Shape out 1 pice at a time hold it or glue it in place when u get one u like glue it in place. Houber fright got a nice pipe bender 4 around 100$ .trail and error go's a long way your only real expense will be the wielding it will take about 16-20 hrs 2 wield up both sides..per bent pieces easy 2 find u save 5000$ easy..get on you tube this ant rocketc sience..post up lots o pic ..ever tom dick and Harry will have something to say. .some of it will b good
LukasM 10-29-2018 07:46 AM
Does anybody have a video or sound clip from the 180° header car that Renegade Hybrids (or anybody else) built?
If you are planning to build your own, there are now header modelling kits available from a few companies like https://www.icengineworks.com/how-it-works/ that will make your life a lot easier. They are not cheap but will save you dozens of hours, and you could buy it used and then sell it afterwards to another builder.
https://i1.wp.com/www.profusioncusto...op-banner2.png
https://i1.wp.com/www.profusioncusto...nd-banner2.png
