-   Porsche Engine Conversion Tech Forum (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/)
-   -   Audi V8 in a 924. (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/941956-audi-v8-924-a.html)
Golten951 12-29-2018 08:05 PM
Updates!
Finally get to work on my 924. Got the Steering rack in place. Now fabricating the oil pan. Going pretty smooth so far.
http://forums.pelicanparts.com/uploa...1546142538.jpg
Golten951 01-01-2019 10:19 PM
Oil pan
Oil pan build in progress, getting the basics all libed out. Have a ways to go still vwfore done.
http://forums.pelicanparts.com/uploa...1546409785.jpg
Golten951 01-02-2019 05:50 PM
Finally on ground
Finally on ground. Have more to do, but least she can be moved around the garage if needed.
http://forums.pelicanparts.com/uploa...1546480031.jpg
Golten951 01-03-2019 01:06 AM
https://www.youtube.com/watch?v=3DZTeh1uXtQ&feature=share
My youtube walk around
Golten951 03-01-2019 07:42 PM
Double U joint
My Double U joint and bearing arrived for my Steering column. I will be installing it in a week or so. http://forums.pelicanparts.com/uploa...1551498175.jpg
Golten951 03-04-2019 07:04 PM
Clutch Set up
Here is My clutch set up for my Audi 4.2L 924. got a hold of a lite aluminum flywheel Looks just like the 034Motorsports series, LuK pressure plate and Disc scored for $160 lol. **Disc is near perfect and will be spared for our 2.7T Passat. The disc pictured is a Mazda Rx8 stage 4 series good for 450ftlbs, which is plenty. it is a 240mm disc, with a 25mm/23t, also for you 951 guys, this disc is a perfect replacement for a worn out disc in your car. average cost is $70 for the Mazda Discs.
http://forums.pelicanparts.com/uploa...1551755035.jpg
Golten951 03-09-2019 09:05 PM
Steering arm
Got my steering arm and U joints set up, need a 42MM ID bearing for the double U joint. Then I can continue more progress! Took a few more pictures of the engine placement too
http://forums.pelicanparts.com/uploa...1552194126.jpg
Golten951 08-27-2019 08:25 PM
Update
I am breaking away from all stock gauges for my Audi 4.2L Swap in my 924. Main reason is I would like to try and make this car Legal in CA to actually drive around. So I am going to use an A8 cluster and, match everything up with the harness. also will have the OBD2 port set up, so I can read any codes and trouble shoot as much as possible. At first I wanted to stay stock gauges, but in the end, this will be very accurate.
http://forums.pelicanparts.com/uploa...1566962702.jpg
Golten951 09-03-2019 09:13 PM
Update
Modification of Harness from the 2001 A8 donor car underway, trimming it down to what is needed for my 924 Audi 4.2 Swap. leaves me with a lot of extra wiring for splicing if needed. Also the fuse block will be a nice update from the old ceramic fuses not to mention the wiring from the early 80s.
http://forums.pelicanparts.com/uploa...1567570350.jpg
jadewombat 09-06-2019 01:35 PM
You'll probably shed about 50 lbs. of weight out of that harness it looks like.
Golten951 09-06-2019 04:10 PM
oh yes! it is crazy large. it is down in size a lot!
http://forums.pelicanparts.com/uploa...1567811367.jpg
Golten951 10-07-2019 10:35 PM
https://www.youtube.com/watch?v=xsYmkN9mptQ&feature=share
Update Video :-) :-)
Golten951 10-08-2019 01:45 PM
Last Update until December.
Last update on my 4.2 swap 924 until December.
Had a good plan forward for my radiator, Brake and clutch. Plus possible Fusepanel layout.
https://www.youtube.com/watch?v=HnKwLaSBGnM&feature=share
Golten951 11-05-2019 12:09 AM
Bit of a thought update, I have been working through ideas and ways to have functioning AC and Heating in my 924. If I leave the stock set up, I will only be able to run Heat with no AC. So my plan is to adapt a 85.5 HVAC interior unit into the cabin. I managed to get the whole interior unit for free, with wiring so if it done not end up working out, there is no lose at all, just possibly a more costly way of getting AC. reason for this change is I have to mod the firewall to keep the engine at a good location and set back in the engine bay, this mod took away the room for the stock AC unit that normally sits in the passenger foot well. Once I can work on my swap in Dec, I can get a lot more practical information.
wayner 11-05-2019 01:39 AM
I like how low and back that engine is placed
Golten951 11-05-2019 12:46 PM
Thank you, was part of my goal instead of using a 60mm to 80mm spacer and push the engine forward.
Golten951 11-06-2019 01:22 AM
Another fun update. since I will have the A8 Interior wiring, I will be using the A8 Headlight switch, turn signal and wiper stalks, plus the Ignition switch and key. Will have to do a little custom fab work... but what has not been custom on this whole swap?? lol., will update more as I go.
Golten951 11-07-2019 02:11 AM
Some pictures.
http://forums.pelicanparts.com/uploa...1573121387.jpg
Golten951 11-07-2019 02:23 AM
Pictures ^_^
http://forums.pelicanparts.com/uploa...1573122169.jpg
Golten951 11-08-2019 01:20 AM
Interior Plans
I am going to be using our Family Tartan and redo the interior of my 924. Already have some good bases set up and plans. I plan to redo the Dash as well while making it to accept the A8 Cluster. Upper half will remain Leather and lower half will be the Tartan. I might do some seat work.. might.. lol
http://forums.pelicanparts.com/uploa...1573204675.jpg
