Audi V8 in a 924.
Hi All,
I am currently working on swapping a Audi 4.2 V8 into my 82 Currently working on getting everything squared in place then building engine mounts and Oil pan. 924. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Toofah King Bad
Wow, please bring this thread over to 924board.org... you'll get lots of love over there.
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc Last edited by Rasta Monsta; 01-13-2017 at 06:56 AM.. |
Most certainly will! Thank you for the kind suggestion ^_^
Toofah King Bad
Engine swap subforum is here: http://www.924board.org/viewforum.php?f=2&sid=b68de0e34a176e6879926658d857c593
Sent from my Amazon Jem using Tapatalk
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
Wow! Awesome stuff. I "think" you'll need a bigger or an additional radiator though. The RS4 I had a few years ago got up to operating temperature within like a minute after I started it and always seem to have a great amount of heat up in that area under the hood.
'66 11-window VW Bus (Fuel-injecter'd Super-1600, IRS, disk brakes, MB CLK rims) |
Thanks Jadewombat its been a fun project so far! I was thinking of the heat, so I went with of a triple core 26x19 radiator. also using a 19" dual speed fan. ^_^
If the fans are running all the time and you find you need more cooling, maybe some downward scoops in the hood. It would also improve downforce on the front end.
The Dodge Hellcats use this also. They made street cars that are made to run flat-out for a full 20 minutes. This green 911 is/was on here from a few years ago and the owner fabricated the downward scoop. I've seen similar on 944s also.
I will most certainly keep this is mind, I do appreciate the information.
Any updates?
What year V8 is it? ABH/ABZ? Curious what clutch fly wheel combination you were planning to use |
I will be using the duel mass flywheel and pressure plate from the 2.7T Audi, then a Mazda/Ford 2.3L turbo clutch disk. Year engine is 2001 ABH If not mistaken. I will double check that number when I go home. Engine was pulled from a A8L with everything on it, paid $900 shipped. |
Nice. That should be an AUX engine, I did not know they might fit the chassis. I have 2 D2 Audis, great cars. You can get a whole car with a dead trans for $1000 or so and sell a bunch of parts to recoup costs. The engines are pretty robust although can get carboned up, maybe due to cheap gas.
The stock ECU is mated to the cluster and pared with the ignition keys so you may have to deal with the immobilizer if you are running the stock ECU. -Joel.
1987 928S4 1992 968 cabrio 2009 957 Cayenne GTS |
ECU is already been reworked, so the VAG/IMO systems and the ties to the Auto trans have been removed. Thank you for the information, If i blow this engine up I will give you a call ^_^ |
Will the bell housing bolt straight up to the 924 Torque Tube? They look compatible...but what kind of bellhousing is on the back of the V-8? Is that the one off of the 924 engine?
Toofah King Bad
931 bellhousing bolts to some audi v8s, but requires clocking the torque tube.
Hi, The Bellhousing is from a 924 turbo, with a Audi V-6 Spacer welded to it so i have more bolt holes to fit to.
Does this all fit under the hood or you will have to modify it?
Updates
Hey Friends, Sorry i have not been able to do anything new with my V8 swap. In December I will have some good time off to do some work my swap ^_^ ^_^
hope you never get in an accident, those long members look pretty fragile w those mods.
