-   Porsche Engine Conversion Tech Forum (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/)
-   -   Backdated Subaru Swapped Targa Rat Project (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/984744-backdated-subaru-swapped-targa-rat-project.html)
sparrott 01-19-2018 11:27 AM
I have been a long time lurker on this forum with great admiration for the level expertise exhibited in project cars here. So I have had a long term project 1977 911 targa that is in the process of getting backdated and a subaru swap. Transmission is a 3-speed sportomatic with adapter plate and custom torque converter. Engine is an high mileage EG33 flat 6 with some crudely made carb intakes with a pair of DGES 38mm synchronous carbs. Hope to have it on the road this summer and possibly in the paint booth this fall.
http://forums.pelicanparts.com/uploa...1516389940.jpg
Eric at Pelican Parts 01-19-2018 12:23 PM
Wow, that's a very interesting swap you have there! I never get tired of seeing the ingenuity our members have with motor swaps. Looking forward to seeing updates on your build, please keep us updated!
Matt Monson 01-19-2018 07:01 PM
Bloody hell, that is positively Mad Max. Welcome to the board. Wild project. Search the archives. The worlds first EG33 911 swap was documented here about ten years ago. It’s a very detailed thread.
v2rocket_aka944 02-06-2018 10:09 AM
why carbs, rather than the Eg33 EFI?
sparrott 02-13-2018 09:37 AM
Well, as great as the EG33 EFI is, the length of the OEM wiring only reaches the rear seat area. I struggled with a nice way to clean up the install and I still wanted to have my kids ride in the rear seats. So I said what the hell and started making carb manifolds on the cheap.
sparrott 02-14-2018 08:05 AM
Coolant lines
I have been asked how I did the cooling system, the short of it is that I am still fabricating the coolant system. I emulated the work done by Peter Sullivan and his EJ25 conversion of his 912. The coolant lines are wire-reinforced marine grad hose ran through the heater channels and then into the frunk. I am using a very thick but short radiator instead the typical large radiator tilted.
Here is Mr. Sullivan very well done 912 conversion (I think has been on this board before):
https://get.google.com/albumarchive/102497299695954962887/album/AF1QipNmZw5yqysBS5sIr5RZmGGapUTlh8jTw7qncX_F
