| Registered Join Date: Jan 2009
				C.O.A. please explain
			So I know in the old days, several years ago, when you ordered a C.O.A. they would list the original engine and tranny number on it. I guess due to scams and number altering on the case, they quit doing this and you have to supply the numbers. If they match they write, "Numbers matching" next to the numbers you provided. So why are so many C.O.A.'s that I'm seeing on bat where the seller says its numbers matching, does it not read numbers matching on the C.O.A. They appear to be newer C.O.A.'s which are signed by Klaus Zellmer. I just purchased one on my barn find, and it returned reading, "Numbers Matching". Please explain.
|  02-23-2019, 04:57 AM |
| Registered | Quote:
|  02-23-2019, 05:21 AM |
| Registered |
			It’s too bad as the days of hunting down a cars missing engine and trans are over
|  02-23-2019, 05:22 AM |
				 | Quote:
|  02-23-2019, 05:43 AM |
| Registered Join Date: Aug 2017
			I’ve gotten myself into a bit of a pickle over this particular issue with semantics.  I, too, was under the impression that if they returned an engine and/or tranny number, those numbers would be the ones for your car.  I supplied two numbers, one for engine, and one for tranny, and received a COA with the numbers matching that car.  The confusion started when the tranny number was not the number I supplied.  The COA did not report the number I provided.  I assumed if the numbers did not match, they would not have reported the correct number due to the risk of the fraud issue above.  Nevertheless, I had a COA with a number and nothing to note it was incorrect.  Time passes and I check the numbers against each other....totally different and down a rabbit hole I go.  I find my wrong turn when I check application and see I supplied the number I had, but they returned the correct number for the car. After a few emails, PCNA replies they only notate “Matching Number” or “Not Confirmed” on cars produced in 1979 or EARLIER. Anything after that it seems they return the numbers associated with the car....regardless of what you may or may not have provided. Just replying to the thread to maybe help another owner eliminate the hassle and axiety of number differences. End | ||
|  02-23-2019, 05:26 PM |
| Registered | Quote:
|  02-23-2019, 06:24 PM |
			Just for reference, this was for a COA dated 10/7/17.
|  02-23-2019, 07:18 PM |
				 | Quote:
 Thanks for sharing your experiences!! Last edited by robertmark; 02-24-2019 at 11:09 AM.. | ||
|  02-24-2019, 09:59 AM |
| Registered | Quote:
|  02-24-2019, 04:58 PM |
			Nathanbs- That was the assumption I was operating on...that if the number provided did not match records, it would be noted as “Not Confirmed” or left blank altogether. What I got was a COA with with engine number I provided but nothing noted (“Matching”??) and trans number I DID NOT provide (the correct transmission number it so happened) and nothing noted. COA has all the correct numbers, only some of them not provided by me. That was when they told me Matching/Not Confirmed would only be provided for cars produced in 1979 or earlier. I just assumed both numbers on mine were provided by me, and with no “Not Confirmed” anywhere, they matched records. Too many assumptions on my part, only unwound by knowing what I actually provided. I found it helpful to double check what I provided with copy of application. | ||
|  02-24-2019, 07:12 PM |
| Registered | Quote:
|  02-24-2019, 07:30 PM |
| Registered |
			The VIN report that Suncoast offers does have the engine and transmission numbers on the report. I checked that report against the numbers that are on my car and they match. You might try that, only $10.
				__________________ Ralph W Instagram @ ralphwlll 1990 C2 Cab 2006 Nissan Frontier 1986 F250 Last edited by Ralph3.; 02-24-2019 at 10:21 PM.. | ||
|  02-24-2019, 10:16 PM |
| Registered Join Date: Sep 2004
				 | Quote:
|  02-25-2019, 04:04 AM |
| Registered |
			Bought one a couple of weeks ago for my 1990 cab and the information was on the report.
				__________________ Ralph W Instagram @ ralphwlll 1990 C2 Cab 2006 Nissan Frontier 1986 F250 | ||
|  02-25-2019, 05:29 AM |
|  02-25-2019, 10:39 AM |
| Registered |
			I didn't supply anything besides the VIN and $10. Got an email back in a couple of days with a pdf file attached. Listed a variety of information including Engine number, Transmission serial number, option codes, exterior paint, top and interior specifications. Went out in the garage took a picture of the number stamped on the case and it matched the number on the file. Admittedly I have not checked the transmission but all of the information on my under hood/ owners manual sticker and engine number match the report. I have been too cheap to buy COA for a 1990 Cab, but appears that my car is matching numbers, not that it really matters but it's fun to know.
|  02-25-2019, 03:36 PM |
				 | Quote:
|  02-25-2019, 03:41 PM |
| Registered |
			Yes, saw it mentioned in another thread on rennlist.  I have started to receive junk mail from Suncoast though....
|  02-25-2019, 04:04 PM |
