I have 50 + people who bought the cases. In at least a dozen of these cases, the buyers were strongly considering used core motors to buy as a starting point for their builds. So what I am suggesting is that since they did not buy the core motors in the past few months, that the core motors are languishing a little, and it's driving the price down. It's just a hypothesis, you don't need to get all upset. |
gearhead
![]() I'm not the upset one. Sorry I questioned your influencer status.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
gearhead
Hey I understand only liking redheads...... my question is have you ever driven a 2.0l MFI S?
Again, I have no issue with preferences, just curious....
63 356 2.1 Rally Coupe 75 911M 2.7 MFI 86 Sports Purpose Carrera "O4" 19 991.2 S |
No. I’ve got zero interest in long hood narrow body normally aspirated 911s. Just not my cup of tea. I can’t imagine I’d get much of a thrill out of it though.
gearhead
A 2l S engine is something special. It’s a baby 906 engine. Don’t knock it until you try it, even if it’s not your preference. I know beer drinkers who still know a good wine when they taste one.
and some who don't...
1971 914-6 GT 3.6 1974 911 1976 911S leaf green backdate 3.2 |
r-mm, lots of work and $$$$$ to stuff a 993 TT in a earlier turbo chassis. This 993 TT by Imagine auto installed in a 88 930 w/4spd. Lots of changes to get it in and 993 oil system is really a lot of re engineering to get everything to fit into a 88. This one was done by Bavarian Rocket Scientists.
Anthony @ Voitureltd Bayside WI. Last edited by voitureltd; 08-03-2019 at 07:09 AM.. |
I have a 3.3L with a G50 LSD. 1 bar spring. Turbo kicks in at 2500 rpm and is very linear on up. Sure 1st gear is short, but 3rd gear merging onto the highway is down right a scary freight train. 5th gear Is the perfect cruising gear.
1973 targa hot rod; 91 Miata. M coupe sold 1977 911s; E39 m5 |
I still have a problem finding 993 engines and transaxles at a reasonable price. The transaxles jumped from $3k all day long to $13k and the engines from $13k to anywhere from $16-$20k depending on needs. The biggest expense are the cylinder heads. Finding even cores is tough, used in good condition can run $2k+ a head and you need 6. At that point might as well go billet aftermarket.
I am building a turbo engine out of an N/A 993 case it can handle the power no problem. Transaxle has steel gears and shift forks.
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, 91 C4 converted to C2,'93 964 C2, '93 928 GTS M '94 Turbo 3.6, '15 Boxster GTS M,16 GT4,23 Macan GTS, Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS 14 Cayman S, 18 Macan GTS many others Last edited by Cobalt; 08-03-2019 at 10:22 AM.. |
Always Be Fixing Cars
Saw this on CL. Realize its a 964 not 993 motor but seems priced about right if truly turnkey. https://newyork.craigslist.org/mnh/pts/d/new-york-city-very-rare-porsche-liter/6931198908.html
'91 964 C4 - New Daily '73 Alfa GTV - 90% done 50% to go '65 912 - Welding in process |
^^^ 325HP on a 100% stock engine. LOL I don't think so. It also has the aluminum intakes so probably an early 91 so it will need the head and cylinder update. I regretfully sold a similar engine about 6 years ago all I could get was $3500 at the time with 4 broken head studs needing the same TSB addressed. Boy have times changed.
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, 91 C4 converted to C2,'93 964 C2, '93 928 GTS M '94 Turbo 3.6, '15 Boxster GTS M,16 GT4,23 Macan GTS, Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS 14 Cayman S, 18 Macan GTS many others |
