Price Check on rebuilt 76 engine
I have acquired a rebuilt engine and honestly do not know the worth, but I'm thinking of selling. Any help would be greatly appreciated.
Specs:
76 7R case redone by Ollie's
Heads redone by Ollie's and setup for twin plug
ITBs, but missing the final fuel injection setup (quoted from Al Kosmal $2,420 to be running)
All surrounding engine tin
Shroud/Alt/Fan
Exhuast back date and pre 76 heat exchangers
So it would need a muffler and the remaining pieces from Al's kit to be a running drop-in distributorless/coil pack/twin plug engine
83' Coupe - Ex-RaceCar
77' Targa Narrow Body - SC powered
Copper Brown Metallic
Old 07-15-2020, 11:25 PM
gearhead
What cams? What p&c set?
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 07-16-2020, 04:12 AM
Matt!
I was hoping you would chime in. Cams are stock. P&C ill need to check. I want to say Mahle Nikasil.
Old 07-16-2020, 05:57 AM
gearhead
Not really sure what the point of twin plug is on stock cams. Would also need increased compression ratio. Rarely do people twin plug under 9.5:1, and usually it's higher, like 10+
1974 914 Bumble Bee
2009 Outback XT
Old 07-16-2020, 06:25 AM
