Value on ‘69 s motor
Hi I’m looking for insight on value on this 1969 s motor. My plan with it is only to use as a practice motor to disassemble and assemble to learn and prepare for the rebuild of my ‘79sc motor when the time comes. There is no known history so assume core motor.
Thanks ![]()
gearhead
Why is the fan shroud the wrong color?
Maybe post the type number and serial number to verify? Personally, if it’s an S, it is likely worth more as it sits than after you tear it down and put it back together. Anyone shopping for a real S engine for a restoration or hot rod is going to rebuild it again and not trust your work.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Where's the MFI?
gearhead
$3-4k? Carbs are worth about a grand and the longblock is the balance of the value.
Matt - 6390793 but 901/10. Was a 2.0 when I got it years ago, correct? Went to a C&C this morning and had 69 parts pointed out. Some I knew, some I didn't.
gearhead
That’s a 69 S engine.
7.0:1 > 11.3:1 > 7.0:1
640xxxx is 914/6
The 9 Store
All used parts sold as is. |
gearhead
914/6 thanks for the info. If I was able
To mate it with a chassis without a transmission.. what’s it worth now? I really wanted a Porsche motor to practice on but scenario is making this interesting. |
More specifically yet this would be from a 1970 914-6 in USA spec and fairly early in the production run. Maybe in the first 300 cars. Even so, as a rebuildable core 4k max.
gearhead
Yeah, my value doesn’t change with it being a 914/6. It’s basically the same thing as a 69T.
Practice on it without much concern. Once it’s turn down, it’s the case with the serial number that might be of value to some 914/6 owner.
Zink Racer
You may want to post the number on 914world.com once you have it. There are guys looking to reunite their factory 6 cars to the original engine.
Jerry 1983 911 SC/Carrera Franken car, 1974 914 Bumblebee, 1970 914-4, 1999 323ti |
I went ahead and started a thread on 914world to link it.
Hey! Nice Rack! "Celette"
Still looking for 4371 Not many 914-6 owners really want the 2.0 in the car. More of a shelf critter to say you have it.
Early Alien Sightings 914-M28/11 5.0 Hybrid (The Alien Sharkster) I think I smell your blood in the water WCC 04 done by the kids Who says Aliens only abduct people. Last edited by rich; 06-10-2024 at 08:05 PM.. |
