944S with 16v vs 951 engine
I just bought a very nice 944S with no engine. Will the car be worth more with a 16V engine or a 951 engine? Both will have to be freshened, but I already have the turbo engine. Thanks for your opinions.
Driving............................Restoring 1988 944 TurboS..............1958 Alfa Giulietta Spyder 1971 Jaguar XKE coupe 2001 BMW 330CI |
It will be worth more as a turbo (a much better engine), but it will also cost more (and be more of a PITA) to do a proper conversion to a 951 motor. To do it properly, the 951 should have the 951 transmission and radiator (a larger unit that won't fit in the 944S bodywork...would need the different 951 nose). I'm sure there are other things I'm not thinking of. An easier transplant would be an S2 motor into the S...just need the motor, ECU and wiring harness. Of course, with either of these you will also still have the 944S brakes, which are smaller than those of the 951 and S2 (though adequate on the street...more of an issue on the track).
Harry '95 993 '90 964 |
