Early 911 "S" Cams, what are they worth?
I sent my cams off to the local Porsche cam expert and he told me they are early 911 S cams. Does anyone know what they're worth? I am likely going with a modified solex grind, so I don't need to mess up a good set of early hotrod cams.
I'm pretty sure (assuming I wrote down correctly) they're stamped 101.105.110.01 and 101.105.109.1R with codes 27267 and 41066 |
If the cams are for carburated S models 66-68 ,they should easily be worth $350-$600 ,
should they be later and have the MFI pump drive gear mount they could command an additional $300 depending on condition. If you're interested in Solex grind I believe a set may be available on one of the forums,Bert
GT2 RS 3.2 RSCS 3.8 R 2.5 Twin Plug |
Did you sell your cams as of yet,possibly interested ,thanks Bert
