Puma's Avatar
SC extended front pan value?
I may just buy correct '68 pan parts for my car so I might sell this but have no clue as to the value. Any idea?
Old 05-31-2016, 08:44 AM
gearhead
Restoration Design's replacement version runs $200 new. Some may value original factory sheetmetal a little higher. Others won't consider it worth any more than the replica parts.
Regards,
Matt
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 05-31-2016, 08:48 AM
That looks like an aftermarket front pan, correct?
Old 05-31-2016, 08:57 AM
Puma's Avatar
I'm not certain if it's aftermarket or not. There's a sticker but I can't read it.
Thanks for the info.
Old 05-31-2016, 10:09 AM
gearhead
I'm no sheetmetal expert, but if there's a sticker it is likely aftermarket. Original factory sheet metal was primered in a sort of greenish primer.
1974 914 Bumble Bee
2009 Outback XT
Old 05-31-2016, 10:20 AM
tholyoak's Avatar
Likely like a Dansk pan.
Should work perfectly fine for your car, just weld on the tow hook and use the correct gas tank support/battery tray from restoration design
1989 911 Targa
Old 05-31-2016, 12:21 PM
Puma's Avatar
I think what you're suggesting would be the best/ easiest route. Thanks.
Old 05-31-2016, 01:40 PM
