Catastrophic Engine Failure. 2007 Carrera 997 please help
So i just got the call from the tech that my engine is gone. IMS bearing went out and tore the inside to shreds.. I am at a loss what to do here. No warranty left. Its basically a paper weight now..
Does anyone out there know if i can sell this car with the engine gone? its only 78K miles on a 2007 . all service well maintained. Silver color. please help me out guys.. any advice would be super welcome. thanks |
Bummer. Sorry for your loss. Head over to Rennlist.com. They have a bunch of threads and expert opinions regarding IMS bearing failures...You can sell the car without a engine but don't expect much.
thank you for the info.. i will check it out.. maybe someone can tell me what its worth.
Man, no real advice but that sucks. Sorry to hear it.
It could be your new highend front lawn ornament now..lol
you can get a replacement engine from Porsche or a used P car yard So many out there now a days perhaps upgrade to GT3 or 3.8S what do you need for it and where is it?? good luck |
Yah.. i was thinking about taking it to the farm and having a bonfire with it.. would make a great video. i dont want to spend any more money on it..
i called a yard about a engine and they said 11K used with core swap. |
The sad story of some 911's ... Broken bits and then it sits..
Thanks the Gods nobody knew how to make a MFI run 40 year ago.. :D Fix it back up and make a hot rod man learning some fun stuff about the 997 along the way |
Has anyone done a 997 LS swap yet...? http://forums.pelicanparts.com/suppo...eys/icon26.gif
Unfortunately there's not a ton of value in a non-S 997.1 roller....I'd bet a dismantler would give you $8k, with retail value probably around $17K depending on options (but it will take a long time to sell off). The $11k 3.6 m96 motors are ebay specials and probably have 100k miles on them. They are realistically $14k motors (for decent ones) plus install. Once a shop finds out your core is IMS related they won't offer you dick for it. Do you race? Best, and most non-nauseating path for you would be use it as a base for that race car you've always wanted |
thanks Mehoff... yah i feel nausea already coming on... HA.. thanks for the good info.
Post it on racing sites such as Racing junk Someone building a dedicate track car or swap would be your target audience.
That sucks!! |
Thanks for the advice. I will check it out |
I'm curious - any particular cause to explain the IMS bearing going bad? Did you track the car, AX perhaps?
I always thought that if the bearing didn't fail early they rarely failed. I haven't heard about many 78k mile cars throwing a bearing.
Guys like me that rebuild cars all the time would buy it. To me, if its in nice shape, it has at least some value. Dump that turd engine, put in a 4.0, away we go.
The problem is now your are buying a car with no motor. So in my book, sub 10K value. |
I'd say 8-10K for a roller, if it's in good shape.
Do the renegade V8 swap and just drive it... Or find a cheap 996 and swap the engine, then sell the 996 as a roller. |
Three choices really:
- Sell it as a roller, walk away and take the hit. - Source an engine from a legit dismantler like Oklahoma Foreign (not ebay) and replace. - Go big and drop 25k on a 4.2L from Vision or other legit engine builder. If it were a 993 most here would almost certainly invest in the quality fresh motor at 25k and just consider it part of the cost of Porsche ownership. |
Looks like you can buy an engine for $13k.
What would installation be? $3000? |
Porsche really screwed up on some of these, I'm not sure if anybody knows the exact issues (why some fail at low mileage but most don't). One of my engineer friends thought it was because the bearings were installed improperly at the factory (slightly off center), and that is why most failed at such low mileage. I think the failure rate was estimated at 13% or so. I have heard of a few at 50k+ miles. Sorry about your loss, I really hate these stories. If you really liked the car I would try to save it, Porsche should step up and sell replacement engines at cost to owners when the IMS let go - I don't care how many years later, that's crap engineering somewhere, 13% is unaccepteble... |
In post number six, the OP said that he did not want to spend any more money on the car, so doesn't that mean all the "build this, that or the other out of it / put engine x, y or z in it" suggestions are not on the table for him (unless any of those builds are free :))?
