Go Back   Pelican Parts Forums > Porsche Forums > Porsche Panamera & Taycan Forum
It'll be legen-waitforit
stealthn's Avatar
Sport cats or Cat delete
Hi,
Anyone put on sport cats or gone with cat delete for their pano?
Considering the FVD sport cats and resonator delete, but dang it's pricey.
Would like a little better sound and a few more ponies would be nice (to see if I can take it over 600)
Bob James
06 Cayman S - Money Penny
18 Macan GTS
Old 02-28-2020, 08:42 AM
i was looking at the fabspeed setup. did you ever get anything for the exhaust? was thinking of leaving the stock mufflers but changing up to them.
Old 06-29-2020, 04:56 PM
stealthn's Avatar
I haven’t yet but I will, just waiting for exchange to go down. I have sport exhaust so I won’t change out the mufflers. Debating cat delete as sport cats are over twice as much, and probably a resonator delete too.
I have the tune so that’s no problem. I will post when I get when I decide
Bob James
18 Macan GTS
Old 06-29-2020, 05:26 PM
stealthn's Avatar
Going with Cat deletes (mainly due to price). They are on order and FVD has already supplied me with the flash upgrade. I will test them first for sound/drone/performance then decide if I want to do a resonator delete as well.
Keeping the PSE on though, can’t wait!
Bob James
18 Macan GTS
Old 07-08-2020, 03:41 PM
i was reading that you would get check engine light with cat delete but think they said at fvd they can get rid of that code with flash update. curious to see how it works
Old 07-08-2020, 08:36 PM
stealthn's Avatar
Will let you know, I have the FVD flash already, with the updated code.
Bob James
18 Macan GTS
Old 07-10-2020, 10:51 AM
seeing how the exhaust is coming. have u received it yet? in the pics it looks like it has cats so wondering if that is just for looks. was wondering how hard the get the bolts off at header. thanks
Old 07-26-2020, 03:12 PM
stealthn's Avatar
Just arrived today... Going on on Wed. I will let you know the results
Bob James
18 Macan GTS
Old 07-27-2020, 08:56 AM
stealthn's Avatar
Just got the PTT back, apparently the bolts at the turbos were brutal so they let them sit in penetrating oil overnight.
I did the flash and brought her home, all I can is WOW! the car sounds unreal, best Panamera I've ever heard. Tried both PSE on and off and what a great combo!
Car sounds like a powerfull V8 now, and it will only get better once the throttle learns it's cycles and the "cats" burn in a little.
I have a video from before so I will take one when I get a helper to show/hear the difference.
I'm really glad I didn't do the reasonator delete as it would have been too loud.
Stay tuned, and THANKS! FVD
Bob James
18 Macan GTS
Old 07-30-2020, 12:43 PM
did the pipes have the round "cat tube" on them. it looks like they do in picture for visual. was worried about those turbo bolts but gonna order one soon.
Old 07-30-2020, 03:20 PM
stealthn's Avatar
Yes, my tech even asked if they have cats, I explained it’s to “pass” visual inspection.
I ordered mine with all the mounting hardware as well as I knew exhaust would be a pain.
The strange thing on the factory ones is they have two bungs, one before the cat and one that looks like it’s in the middle of the cat.
Bob James
18 Macan GTS
Old 07-30-2020, 03:39 PM
are u getting a code with the new exhaust on? that it was you on other site talking about it. was about to order but wanna make sure no codes. thanks
Old 08-05-2020, 06:54 PM
stealthn's Avatar
Sadly yes, getting CEL. I cleared it once then took it to a Porsche tech I know to read the codes. It comes back with an FFFF code which is not a Porsche code.
I confirmed with FVD that the flash they sent me was right for my mods and no CEL should be present. I got the tech to clear the adaptation for Lamda, mixture, boost and fuel pressure (he drove the car before I flashed it) and reset it.
My second drive afterward I got the CEL again, so going back to FVD to figure out the issue.
I will post here when I get more info.
Bob James
18 Macan GTS
Old 08-05-2020, 07:01 PM
stealthn's Avatar
Got a new flash this am, will put on today and let you know
Bob James
18 Macan GTS
Old 08-06-2020, 06:13 AM
Thanks, couldn’t wait so ordered. Guess worse case have to put o2 sensor extension. Saw fvd say u don’t but seems others have. As far as the code it doesn’t put car in limp mode does it. Still drives just annoying light? Thanks
Old 08-06-2020, 07:40 AM
stealthn's Avatar
Car drives perfect, just an annoyance...
Bob James
18 Macan GTS
Old 08-06-2020, 07:44 AM
stealthn's Avatar
Update:
Put on another flash FVD provided and have driven the car 3 times now with no CEL.
I will consider it fixed after 10 drives, but so far so good.
Bob James
18 Macan GTS
Old 08-07-2020, 06:28 AM
that's good. got mine ordered
Old 08-07-2020, 04:54 PM
stealthn's Avatar
Took her out for a drive today with the window down, sound is fantastic! I do hit the PSE button though when in the neighbourhood, I figure the neighbours got enough noise when I had the old 911
Bob James
18 Macan GTS
Old 08-12-2020, 01:33 PM
figure your the man to ask, how do i know if i have sport exhaust. my friend has gts and has little button he pushes and exhaust sounds great. i didn't see sport exhaust listed on my build sheet and i don't have the button on dash. also how the hell do you check the oil. I've tried 50 times and got it to work twice. what is your procedure for checking. just miss my dipstick on all the other cars. thanks
Old 08-12-2020, 03:17 PM
