Key fob and ignition swap
Is it possible to take the starting system (key fobs, ignition, ECU & ECM) from one Panamera to another? I'm really not sure what all the system consist of. I can't find anything online that says what all is involved. Any help would be greatly appreciated. Thank You
Well i'm pleased to say, I Got it. On my 2012 Panamera S I was able to use the parts from a 2012 4s. I swapped out the ECU, ECM, BCM, ignition module, key fob and the gateway. This model has the immobilizer is inside of the ECU. All I have left to do is the door lock on the drivers door to accept the blade from the new fob. A big thanks to my new friend ToddAuto for his knowledge. Car started right up.
Hello there. Do you have any instructions you used to disassemble the dash panels on the driver’s side?
Mine is a 2013 Panamera 4 |
