marcesq's Avatar
915 Rebuild Update
Second day (removed from the 1st day by a week or so).
http://www.pelicanparts.com/MotorCity/marcesq3/TrannyRebuild.htm
Again, if anyone has any tips that could be shared with the rest, please pass them along.
To this point, I have used regular tools, no factory thing-a-majigs, or presses. I did make one tool out of an old clutch plate.
Thanks.
'94 CMC Firebird Trans Am
'86 951 LS1 (C-2) Gone
'77 911 3.2 (C-1) Gone but not forgotten.
http://www.pelicanparts.com/MotorCity/marcesq1
http://www.youtube.com/user/958Fan#p/u
Old 02-01-2004, 02:42 PM
Eugene at Pelican Parts's Avatar
Wow! All that progress from one day! Impressive.
To remove the 46mm nut, I pegged the old clutch to a wall instead of making a tool out of it. Your method might be a bit safer.
Eugene (Formerly) at Pelican Parts
Pelican's E-Commerce Guy, 2003-2011
2001 330i Sport
1983 911SC Coupe (sold)
Old 02-01-2004, 05:08 PM
19 years and 17k posts...
azasadny's Avatar
Marc,
Great job, thanks for the detailed documentation. This will help alot of people when they face the same thing you did. Thanks again!!
Art Zasadny
Learning the bass guitar
www.ford.com
Old 02-01-2004, 05:17 PM
marcesq's Avatar
Eugene . . . you must be single . . . that is a great idea. If it's ok with you I'll add the pic, etc to the page.
Art . . . . thanks . . . I'm the one who is learning with the help of many aboard.
Now for the 2nd half . . . go Panthers . . . (Steven Davis was a Redskin so I have to root for them, closest I'll get to another SB for a while)
Old 02-01-2004, 05:40 PM
Guilty as charged. Here's another one. My synchro hubs were pressed on so darn tight I really wished I had the factory tool for the job. To replicate its function, I decided to sacrifice a couple of those big lock rings and some cheap wrenches by rigging up the thingamajig shown below.
A big socket fit perfectly into the gear. After a LOT of persuasion with a 3 lb sledge, they finally came off the gear. And yes, that wrench bent quite a few times... call it cold-hardening.
2001 330i Sport
Old 02-01-2004, 05:55 PM
