Contentious by nature
Rixster's Avatar
Question 12S air intake
Has anyone done this to their snorkle tube?
I was thinking of mounting a video camera in the fairing
and this would open up the air intake as well
before.....
after.......
'07 R1200S '11 S1000RR
'83 Suz 1100e (2)
"The garage, is no place for a car"
NRA Lifer
Old 08-01-2009, 09:09 PM
No try, do or not do
shreddr's Avatar
take a look at what SJBMW did to their R12S intake, check their racing site.
2017 R1200GSW Rallye Shreddr Signature Model
Old 08-02-2009, 05:32 AM
Or what about just cutting it off at the filter and leaving enough to retain the filter?? Try it and let us know.
Old 08-02-2009, 10:11 AM
shreddr's Avatar
something tells me just cutting that off would be bad, there would be turbulence from the opening in the fairing which probably wouldn't get MORE air into the snorkel, and maybe less. The SJBMW setup appears to be the best effort.
Old 08-02-2009, 10:27 AM
I dunno about that. Opening up restricted airboxes is an old trick. A popular mod on late model Guzzis is to simply remove the airbox top and expose the filter. It eliminates a similar snorkel that seems to be there primarily to quieten the motor down.
Old 08-02-2009, 10:57 AM
Initials & assault rifle
cageyar's Avatar
The R12S snorkle setup provides for a ram air effect.
Cutting it in half with a large opening under the body or removing it entirely will negate that effect and alter the intake flow of air.
If simply removing the snorkle would have yielded a performance boost, I'd have to beleive SJ BMW Racing would have simply removed it.
Instead, they chose to retain the length as well as the ram air effect and simply enlarged the end of the tube.
2007 R12S | OHLINS | PRO PILOT | AKRA Ti | WOSSNER | FRK | BST | RT A-ARM | BRAKING | WERNER | K&N | RIZOMA | R&G | METZELER
1982 CBX | OLD SCHOOL
1969 H1 | QUESTIONABLE SANITY
Old 08-02-2009, 11:07 AM
shreddr's Avatar
here's another look at the SJBMW piece, i think it looks pretty cool, check out the link and find the Mule.
http://www.sjbmwracing.com/
I will also mention that there is probably little real world benefit to be gained by getting more air into the R12S airbox, UNLESS you have significantly increased fueling, which would require some other mods like porting, HC pistons, and some kind of fuel management system. Chris H was running 14:1 pistons, some serious portwork, and a Motec ignition system in order to need that small improvement in the air intake. A stock bike with that might actually run worse because it would just be leaner.
If you have an R11S that is a different story, because for some reason BMW thought that choking the intake of that sportbike was a good idea. Lennies InDuct solves that problem quite nicely.
Old 08-02-2009, 11:38 AM
Rixster's Avatar
Thanks for the input. I can visualize turbulence......especially if I put a video camera in the fairing. And, yes, I believe SJ-BMW did some homework to come up with their modification so I'll have to come up with a different approach.
'83 Suz 1100e (2)
NRA Lifer
Old 08-02-2009, 08:12 PM
