Go Back   Pelican Parts Forums > Porsche Forums > Porsche Autocross and Track Racing
Plavan's Avatar
Race car alignment suggestions.
I'm getting ready to take the car in for a race alignment. I wanted to see what you guys suggest.
I use 205/50 R15 Kumho's victoracers front
225/50 R15 Kumho's rear
23mm torsion front, 30mm rear
Koni adjustables all the way around (hard setting)
22mm sway bars front and rear
Thanks in advance
Chad Plavan
911ST Race Car/2.5L SS Race Motor #02
1972 911T- Numbers matching- Restoring to stock
2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold)
2016 Elan NP01 Prototype racecar- Chassis #20, #02
Old 02-11-2004, 10:08 AM
Super Moderator
cstreit's Avatar
PM'd you...
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 02-11-2004, 11:50 AM
addictionMS's Avatar
hey, that's no fair, I was looking forward to see what everyone is running, now I am going to have to PM mine as well...
Jim
Jim Hamilton
If everything seems under control, your not going fast enough.
Old 02-11-2004, 02:58 PM
Vintage911Racer's Avatar
Send a message via AIM to Vintage911Racer
ALignment
Chad,
Did you get it all figuerd out???
I will give you my specs.
2015 Lbs. wet.
23mm T-bars up front.
31 mm Hollow bars in rear.
19mm sway bar rear. ( some tracks I disconnect it)
22mm sway bar front.
Bilsteins Sport (revalved up front, Koni Adjustable rear (full stiff).
-2* camber in front
-2.5* camber in rear
I think 1/16 toe in at the rear, and 1/8 toe out at the front.
I think. Something like that. I could have them reversed.
But I will have my spec sheet with me this weekend or call me tonight and I can give them to you over the phone.
Mark Scott
Vintage 911 Racer
1967 911S 2.4L ROCKET
Powered by Faragallah!
www.scottassociatesracing.com
Old 02-11-2004, 03:10 PM
Super Moderator
cstreit's Avatar
You first Jim!
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 02-11-2004, 03:27 PM
I was first.
Come on now Boys spill the beans.
Mark Scott
Vintage 911 Racer
Old 02-11-2004, 03:33 PM
Administrator
Jack Olsen's Avatar
Probably not helpful, but here are my specs:
1972 Widebody
2650 pounds with driver and gas. (2370 empty)
400# springs front
600# springs rear
Adjustable 23mm sway bars front rear.
JRZ single-adjustables front.
Bilstein Sports rear.
-2.5 deg. camber in front
-3 deg. camber in rear
1/16toe-in front and rear.
7 degrees castor up front.
Edit: I changed my 'kinda-metric' measurements to standard.
Old 02-11-2004, 03:53 PM
Plavan's Avatar
FYI- If you PM me- I will not release your secrets.
Chad Plavan
Old 02-11-2004, 03:54 PM
Chad......Your gay
Mark Scott
Vintage 911 Racer
Old 02-11-2004, 03:57 PM
I will post mine tonight, but I can't guarantee they are what I am running, I do my own alignment, so what I think I have and what I really have.....well you get the picture..
Jim Hamilton
Old 02-11-2004, 03:58 PM
Plavan's Avatar
Mark- I already have had 3 people PM me their settings because they do not want everyone to see. I think its kind of funny.
Chad Plavan
Old 02-11-2004, 04:01 PM
That is funny. SO is your car ready
Mark Scott
Vintage 911 Racer
Old 02-11-2004, 04:03 PM
Super Moderator
cstreit's Avatar
Originally posted by JackOlsen
Little bit of toe-in front and rear.
Lots of castor up front.
Are those metric "little bits" Jack, or english?
Couldn't resist!
I PM'd mine, it's not so much that I care if youse guys see my settings, but honestly, I'd rather not the whole world....and frankly the first person that criticized them would get a rotten cabbage in their bed.
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 02-11-2004, 04:17 PM
PRO Motorsports
Tyson Schmidt's Avatar
Jack is actually running 3 degrees negative in back. The front is somewhere between 2 and 2.5 negative. We changed it quite a bit for different conditions, so I can't remember where we last left it.
Also, 1/16th" toe-in front and rear.
7 degrees caster up front
Mine are
front -1.7 (all I can get out of it at the moment, would like -2 , and raised spindles would be nice also!)
rear -2.5 (would like to get around -3.2 if I ever find the time to work on my own car)
6 deg. caster
0 toe-in front
1/8" toe-in rear
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 02-11-2004, 09:37 PM
Administrator
Jack Olsen's Avatar
There we go. I'll edit the correct numbers into my post, and make Chris' response look strange to future generations.
Old 02-11-2004, 10:08 PM
I still have not been able to get to my log book, so I will psot from memory
23/31 torsion bars
31/27 sway bars
revalved Bilstein (SRP)
Front
-2.6 degrees camber
all the caster I can get
1/8 inch toe out at rim
sway bar at about 1/2 stiff
205/55/16 RA1 25psi cold
rear
-2 degrees camber
1/8 toe in
sway bar at about 1/4 stiff
245/45/16 RA1 25psi cold
No Fear of the someone having the settings, its my driving that slows me down
Jim Hamilton
Old 02-12-2004, 12:37 PM
Navin Johnson
TimT's Avatar
Ill tell.... I run as much camber as I can ger front and rear... all the caster I can get
rear toe 1/16
front toe 1/16 out
'69 911 GT-5
'75 914 GT-3
and others
Old 02-12-2004, 02:12 PM
thrown_hammer's Avatar
Why max out the castor? I am getting an alignment today. I was planning on MAX negative camber front and rear zero toe front and rear and factory castor settings. My car is a street/ ocasional DE car.
Keeper of the Titanium Monkey
1975 911S (sold)
1973 911 w/3.2 (sold)
1983 911SC targa (sold)
Looking for a 987.2 or 981 Cayman
Old 05-07-2004, 10:47 AM
Super Moderator
cstreit's Avatar
Shawn,
Castor causes your camber to change as the wheels are turned.
The only DOWN side to castor (within reason) is increased steering effort. More castor increases the negative camber of the outside wheel, increaseing grip. The inside wheel tends to get some positive camber added at the same time, also helping a bit...
3-4 gegrees is generally considered standard.
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 05-07-2004, 03:53 PM
Binge User
Schrup's Avatar
My car isn't a dedicated race car, but I had Fordahl Motorsport set it up for DEs, autoX, & agressive driving.
Left Front
Camber -1.0
Caster 5.8
Toe 0.02
Right Front
Camber -1.4
Caster 5.5
Toe 0.02
Front
Cross Camber .04
Cross Caster .2
Total Toe 0.04
Left Rear
Camber -1.8
Toe .09
Right Rear
Camber -1.9
Toe .09
Joey, the tech that worked on my car told me he got as much neg. camber as he could, & the difference between camber & caster would cancell each other out. My ride hieght is 23" front & 24" rear with 1 degree of rake, no bump steer. Any opinions?
Paul
Old 05-08-2004, 01:38 PM
